| brianp626 |
Jul 29 2018, 10:19 AM
Newbie ![]() Group: Members Posts: 21 Joined: 29-July 18 From: Indiana Member No.: 22,351 Region Association: Upper MidWest |
Hi all, new here needing a little help. Let me give you a quick backstory. Picked this car up on Friday. It’s a 73 1.7. Against my better judgement I decided to drive the car home, it started up fine, ran fine. 30 minutes into my commute it’s smoking BAD. Have it towed home. After looking around for a problem I noticed it was missing a hose from the flashback valve (?) to the passenger side head and was pretty oily in that area so assumed it was spitting oil on top of the engine hence the smoke. Replaced the hose. Went to fire it up and it won’t start. Engine oil level seems fine so it didn’t lose much. Any ideas why this would start fine before the incident and now it won’t? Thanks for the help in advance.
| 76-914 |
Aug 1 2018, 08:01 PM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,915 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
Could these be the hoses from the charcoal filter to the fan? Check your fuel line for good flow. Sounds like you have a fuel delivery problem. There are screens in the tank nipples that can become clogged. Your fuel pressure should be about 29psi. (IMG:style_emoticons/default/beerchug.gif)
| brianp626 |
Aug 1 2018, 08:06 PM
Could these be the hoses from the charcoal filter to the fan? Check your fuel line for good flow. Sounds like you have a fuel delivery problem. There are screens in the tank nipples that can become clogged. Your fuel pressure should be about 29psi. (IMG:style_emoticons/default/beerchug.gif) I’ll give that a shot. Taking it to a friends this weekend and putting our heads together. |
brianp626 *N00b* Car Won’t Start Jul 29 2018, 10:19 AM
Spoke :wttc:
Does the engine try at all to start? You ... Jul 29 2018, 10:35 AM
brianp626 Thanks Spoke! It turns over but there isn’t ... Jul 29 2018, 10:44 AM
taylspin46
Thanks Spoke! It turns over but there isn’t... Jul 29 2018, 10:55 AM
The Cabinetmaker Do you hear the fuel pump prime for half a second ... Jul 29 2018, 10:47 AM
brianp626 Fuel pump does prime. Looked around the area of th... Jul 29 2018, 11:57 AM
taylspin46
Fuel pump does prime. Looked around the area of t... Jul 29 2018, 12:26 PM
falcor75 Is the fuel pump in the stock location underneath ... Jul 29 2018, 12:40 PM
Coondog Reset points, clean and lube rotor shaft Jul 29 2018, 12:51 PM
brianp626 Taylspin- CHT looks fine.
Falcor- I believe it is... Jul 29 2018, 12:57 PM
falcor75 Vapor locks go away by letting the car cool down, ... Jul 29 2018, 01:41 PM
Dave_Darling The engine needs three things to run: Fuel, air, ... Jul 29 2018, 02:09 PM
Rand Smells funny to me.
I get something can go wrong ... Jul 29 2018, 02:53 PM
brianp626 **Update** sprayed some starter fluid in the intak... Jul 31 2018, 05:58 PM
Spoke If you haven't done a tune-up on your new car,... Aug 1 2018, 05:21 PM
brianp626 Yea, I’m thinking about taking it to a local Vol... Aug 1 2018, 05:33 PM
BeatNavy Not sure what that is in the bottom picture, but t... Aug 1 2018, 06:07 PM
brianp626
but the top picture is one of the lines that goes... Aug 1 2018, 07:19 PM
Dave_Darling One of those hoses goes from the fan shroud to the... Aug 1 2018, 09:58 PM
brianp626
One of those hoses goes from the fan shroud to th... Aug 3 2018, 11:13 AM
brianp626 I started the car when I got home from work yester... Aug 3 2018, 11:17 AM
Dave_Darling The other hose doesn't go to the throttle body... Aug 3 2018, 01:02 PM
76-914 What is the ohm reading on the CHT sender when it ... Aug 3 2018, 05:18 PM
brianp626
What is the ohm reading on the CHT sender when it... Aug 6 2018, 08:48 PM
brianp626 **BUMP** Update, car starts now. Will run and driv... Sep 15 2018, 03:02 PM![]() ![]() |
Lo-Fi Version | Time is now: 18th July 2026 - 10:03 AM |
