> my adventures in painting the car thread, DONE! Some final thoughts...
914 RZ-1
post Jul 11 2018, 09:55 PM
Porsche Padawan
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting:
After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel:
Option 1:
I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done.
Option 2:
I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray.
Option 3:
I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on.
aggiezig
post Aug 1 2018, 02:25 PM
Porsche Wannabe
You already have a ton of great feedback on this thread but I thought I would add my $0.02 as well from my introductory painting experience.
First off, I am not a fan of HF guns for spraying topcoats. Some of the more experienced guys can make this work but I just don't think those guns have enough adjustment and do a good job of atomizing paint. That's just my opinion. I bought a devilbiss starting line gun kit. Two guns and accessories for under $200.
It sounds like you are using the right temp reducer, but when in doubt always choose the slower (higher temp) reducer and just allow more flash time between coats to avoid solvent pop.
PSI at the gun should be 35-40 with the trigger depressed. Make sure you are setting this pressure correctly, it can greatly affect your outcome. As others have mentioned, make sure your air is clean.
Make sure you are applying medium wet coats with a good 50% overlap. If you aren't getting enough paint on the panel, it will never get a chance to flow out. A lot of times I have to remind myself to slow down when spraying.
After spraying 3-4 coats of color, give the paint a full 24 hours to shrink up and flash before assessing orange peel and other conditions. It takes time for the paint to reach it's final appearance state but it's 80-90% of the way there about a day afterwords.
When wet-sanding, start around 1000-1200 and work up in stages. 1000 - 1500 - 2000, etc. You will need either rotary buffer (dangerous to novice users) or a dual action with enough throw and aggressive pads to get ALL of the sanding marks out. I can general get around 95-98% correction with my dual action using a microfiber cutting pad and meguiars M105 cutting compound. Tape off your edges when sanding!
I'm sure there are other tips I can think of but that's a fair amount of information for now. Your last efforts look much better than when you started. This isn't an easy trade to master, but with a lot of practice and perseverance you can get pretty good at spraying paint as a hobbyist.
914 RZ-1
post Aug 1 2018, 08:37 PM
Porsche Padawan
QUOTE(aggiezig @ Aug 1 2018, 01:25 PM) *
Thanks for the advice. Always appreciated! (IMG:style_emoticons/default/beerchug.gif) Where were you a few months ago! (IMG:style_emoticons/default/poke.gif)
Yeah, I use the slower reducer. I can wait.
I noticed the psi has a huge effect. I'm just an idiot and didn't do this right the first few times. I now check the psi with the trigger depressed.
I never did find any good advice on how fast to move the gun. I tend to go too fast on the big panels. I noticed on the small pieces I was getting a good finish; I was going fast over them.
I sand by hand unless I'm re-painting a panel. I've burned thru the paint too easily. I've even sanded thru it by hand, especially on the edges. Once I get a good finish, I will tape the edges.
I should have practiced more! (IMG:style_emoticons/default/headbang.gif)
914 RZ-1   my adventures in painting the car thread   Jul 11 2018, 09:55 PM
porschetub   Oh dear,let it dry and start again,your paint is t...   Jul 11 2018, 11:30 PM
Front yard mechanic   Option 2 my vote   Jul 12 2018, 07:30 AM
Cairo94507   That's a bit of orange peel for sure. I would...   Jul 12 2018, 07:38 AM
burton73   You are going to need to go through the grits by s...   Jul 12 2018, 10:24 AM
Andyrew   Single stage? What paint are you using? Go 30% m...   Jul 12 2018, 11:05 AM
Andyrew   What temp reducer are you using? and how hot was i...   Jul 12 2018, 11:06 AM
mb911   I would wet sand again.. Then see what you have le...   Jul 12 2018, 11:08 AM
jmitro   definitely need to wet sand with finer and finer g...   Jul 12 2018, 11:33 AM
914 RZ-1   Thanks to all. I appreciate you input. I'm usi...   Jul 12 2018, 06:53 PM
Spoke   It was in the 80's when I painted. I probably...   Jul 16 2018, 11:08 AM
Olympic 914   many years ago I clipped the front end of my teene...   Jul 12 2018, 07:20 PM
914 RZ-1   Here is the result after wet-sanding with 800-1000...   Jul 13 2018, 12:32 PM
mb911   Here is the result after wet-sanding with 800-100...   Jul 13 2018, 03:20 PM
mepstein   Here is the result after wet-sanding with 800-10...   Jul 13 2018, 03:30 PM
ValcoOscar   Yeah Jeff...I kinda think you need more paint also...   Jul 13 2018, 03:31 PM
ConeDodger   Option 4: peel it and eat it. :rotfl:   Jul 13 2018, 06:45 PM
Andyrew   Hand sand only. No DA sanding for color sanding.   Jul 13 2018, 07:55 PM
914GT   Also, use a guide coat to show missed sanding scra...   Jul 13 2018, 08:46 PM
914 RZ-1   Here's the latest. I sanded with 400, cleaned ...   Jul 16 2018, 10:23 AM
Andyrew   Flash time starts from when the paint first leaves...   Jul 16 2018, 12:19 PM
914 RZ-1   I just to-read this and noticed that some people t...   Jul 16 2018, 02:44 PM
Dougster   As far as the paint mix, only do what the tech she...   Jul 16 2018, 04:00 PM
Andyrew   I think I spray at 20-25psi. With the nozzle a str...   Jul 16 2018, 04:00 PM
burton73   I think I spray at 20-25psi. With the nozzle a st...   Jul 16 2018, 08:21 PM
914 RZ-1   Here's the latest: Still a bit of orange peel...   Jul 16 2018, 10:11 PM
914 RZ-1   One other thing: how long are the face mask filter...   Jul 16 2018, 10:34 PM
Andyrew   Primer about 20 sessions. Not much VOC in the air....   Jul 16 2018, 11:02 PM
porschetub   Brave move going to that system for DIY newbie,cur...   Jul 17 2018, 12:58 AM
914 RZ-1   So my a-hole neighbor called the HOA, the city and...   Jul 25 2018, 06:33 PM
bbrock   That right there is why I live in the boonies, but...   Jul 25 2018, 06:53 PM
914 RZ-1   So, I'm still getting some orange peel. I thou...   Jul 31 2018, 04:17 PM
burton73   How long are you letting it sit before you color s...   Jul 31 2018, 04:29 PM
Andyrew   1. Yes. 2. Pinholes are typically from something...   Jul 31 2018, 04:30 PM
burton73   After you color sand, wipe it clean and look at it...   Jul 31 2018, 04:33 PM
ValcoOscar   Jeff- Keep in mind, our current HOT weather patte...   Jul 31 2018, 04:41 PM
Perry Kiehl   If you have a contaminant on the surface no amount...   Jul 31 2018, 05:09 PM
worn   If you have a contaminant on the surface no amoun...   Jul 31 2018, 05:23 PM
914 RZ-1   Thanks all. Here are my responses: I'm lettin...   Jul 31 2018, 05:14 PM
914GT   Don’t overlook the quality of your compressed ai...   Jul 31 2018, 05:39 PM
914 RZ-1   Don’t overlook the quality of your compressed a...   Jul 31 2018, 06:03 PM
Andyrew   [quote name='914GT' post='2634214' date='Jul 31 2...   Aug 1 2018, 11:09 AM
914 RZ-1   [quote name='914GT' post='2634214' date='Jul 31 ...   Aug 1 2018, 12:54 PM
mb911   Prepsol should be allowed to dry /evaporate before...   Jul 31 2018, 05:54 PM
914 RZ-1   Here's the latest: I painted both doors. I pu...   Aug 1 2018, 10:06 AM
Andyrew   What kind of gun with what size tip are you sprayi...   Aug 1 2018, 11:04 AM
914 RZ-1   What kind of gun with what size tip are you spray...   Aug 1 2018, 12:52 PM
Andyrew   What kind of gun with what size tip are you spra...   Aug 1 2018, 01:08 PM
914 RZ-1   [quote name='914 RZ-1' post='2634443' date='...   Aug 1 2018, 08:30 PM
Costa05   I thought I read in one of your posts that you wer...   Aug 1 2018, 12:22 PM
914 RZ-1   I thought I read in one of your posts that you we...   Aug 1 2018, 12:59 PM
Costa05   I thought I read in one of your posts that you w...   Aug 1 2018, 02:27 PM
aggiezig   Thats great. Check out the Eastwood videos on you...   Aug 1 2018, 02:28 PM
bbrock   Thats great. Check out the Eastwood videos on yo...   Aug 1 2018, 02:42 PM
aggiezig   You already have a ton of great feedback on this t...   Aug 1 2018, 02:25 PM
914 RZ-1   You already have a ton of great feedback on this ...   Aug 1 2018, 08:37 PM
914 RZ-1   +3 on Kevin Tetz. I learned most of this from his ...   Aug 1 2018, 08:41 PM
mepstein   +3 on Kevin Tetz. I learned most of this from his...   Aug 2 2018, 07:29 AM
Olympic 914   +3 on Kevin Tetz. I learned most of this from his...   Aug 2 2018, 09:00 AM
mbseto   Man this is a clinic. Almost makes me want to try...   Aug 1 2018, 10:06 PM
914 RZ-1   Man this is a clinic. Almost makes me want to tr...   Aug 2 2018, 06:23 PM
Perry Kiehl   FWIW, I have separate air hoses for only paint use...   Aug 2 2018, 07:18 AM
Rav914   Man this is a clinic. Almost makes me want to tr...   Aug 2 2018, 09:17 AM
914 RZ-1   I found it! Thanks! :beer2: https://www...   Aug 2 2018, 06:17 PM
aggiezig   I think that with enough trial/error & practic...   Aug 2 2018, 08:39 PM
914 RZ-1   Nice job! Yeah, it's taking me lots of pra...   Aug 8 2018, 12:18 PM
914dave   I had the same wrapped up in my paint. Tools incl...   Aug 4 2018, 07:34 AM
914 RZ-1   So I got the suggested filter: https://www.harborf...   Aug 8 2018, 12:15 PM
Andyrew   So I got the suggested filter: https://www.harbor...   Aug 8 2018, 12:42 PM
914 RZ-1   You need to put your regulator after the filter. Y...   Aug 8 2018, 05:57 PM
914GT   You are setting your pressure at the gun with the ...   Aug 8 2018, 07:05 PM
914 RZ-1   You are setting your pressure at the gun with the...   Aug 9 2018, 01:54 PM
Andyrew   Thinking back, I do remember having this issue onc...   Aug 9 2018, 02:01 PM
914 RZ-1   I've got similar orange peel on my hoods; were...   Aug 9 2018, 05:19 PM
Andyrew   Note. Spray the body side in one go, Not panel by ...   Aug 9 2018, 02:03 PM
914 RZ-1   Yeah, that's what I'm doing. I actually ha...   Aug 9 2018, 05:24 PM
Andyrew   Also noticed this review online. "We review...   Aug 9 2018, 02:05 PM
914 RZ-1   Wish I'd bothered to read the reviews. Maybe I...   Aug 9 2018, 05:21 PM
914 RZ-1   I'm STILL getting orange peel. To review, here...   Aug 19 2018, 05:46 PM
914 RZ-1   A picture after wet-sanding with 800 for your view...   Aug 19 2018, 05:54 PM
Andyrew   A picture after wet-sanding with 800 for your vie...   Aug 19 2018, 06:26 PM
914 RZ-1   A picture after wet-sanding with 800 for your vi...   Aug 19 2018, 06:32 PM
dakotaewing   Please show pictures of your compressor, hoses and...   Aug 19 2018, 06:01 PM
914 RZ-1   Please show pictures of your compressor, hoses an...   Aug 19 2018, 06:31 PM
Andyrew   Ya, I put 7 coats on mine when I did it. Took 3 fo...   Aug 19 2018, 06:55 PM
Andyrew   And I agree with temp. If your starting to spray a...   Aug 19 2018, 07:01 PM
dakotaewing   Upon initial review, it would appear that part of ...   Aug 19 2018, 07:54 PM
914 RZ-1   Upon initial review, it would appear that part of...   Aug 19 2018, 08:54 PM
Atech   [quote name='dakotaewing' post='2640512' date='Au...   Aug 20 2018, 01:40 AM
Atech   [i][quote name='dakotaewing' post='2640512' date...   Aug 20 2018, 01:52 AM
dakotaewing   The water trap on the wall will only catch a small...   Aug 19 2018, 09:35 PM
aggiezig   Lots of good tips about air and what not, but base...   Aug 20 2018, 08:22 AM
914 RZ-1   I have been told that compressed air can be very h...   Aug 26 2018, 02:54 PM
mb911   I have been told that compressed air can be very ...   Aug 26 2018, 03:17 PM
porschetub   [quote name='914 RZ-1' post='2642822' date='...   Aug 26 2018, 05:37 PM
ConeDodger   Get rid of that first length of hose of the compre...   Aug 26 2018, 04:03 PM
porschetub   Get rid of that first length of hose of the compr...   Aug 27 2018, 12:22 AM
IronHillRestorations   I'll 2nd Ben's opinion. I think you proba...   Aug 26 2018, 04:39 PM
IronHillRestorations   I've had more than one painter tell me that ea...   Aug 26 2018, 08:30 PM
gereed75   Lots of great info here. Don’t get overwhelmed. ...   Aug 27 2018, 07:26 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 08:38 PM
