| dr914@autoatlanta.com |
Aug 3 2018, 08:43 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,247 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
| rhodyguy |
Aug 3 2018, 09:24 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,254 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
What does HO stand for? (IMG:style_emoticons/default/confused24.gif)
| Coastal6 |
Aug 3 2018, 09:37 AM
Newbie ![]() Group: Members Posts: 47 Joined: 15-March 10 From: Florence, OR Member No.: 11,467 Region Association: Pacific Northwest |
Horrible outcome. (IMG:style_emoticons/default/smile.gif) |
| Tom_T |
Aug 3 2018, 10:51 AM
TMI.... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,321 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California
All - Well that was certainly the result after an engine fire due to battery acid corroded OE cloth-covered fuel lines, but I doubt that was what Porsche had in mind! (IMG:style_emoticons/default/biggrin.gif) I'm adding the recall info below, because it's important to all members & all vehicle owners, regarding recalls - but first.... As Jeff said, it's the "HO Recall" required by NHTSA for all 70-76 914s, & if yours was never done, then Porsche/PCNA is still required to do them today. In fact, this is the case for any open recall on any car make & model no matter how old, if never done & documented. That's the USA Federal Law, & I'd imagine it's the same in other countries too. Just contact PCNA. They'll probably ask you to bring it to a dealer - or send someone out if not running, in order to verify that it was never done. I know this for a fact, because I went through the process on my own 73 914-2.0, & have my letter from PCNA to contact them & bring it in to a local dealer to have it done, whenever I have it running & registered again, since the PCNA District Manager already came out to my house to verify it. This is VERY important for ALL of you folks cars - so don't let the local dealership BS you, they do have to do all recall work if never done, but you may have to go to the car manufacturer &/or NHTSA to push the issue through. So check all of your cars for open recalls - the newer ones with the later VIN code format (1980's started) can be done with the NHTSA Recall Look-up using your VIN. For older vehicles with the older you'll have to send an email or postal inquiry to NHTSA, then follow-up with the dealer(s) &/or manufacturer(s) to get them set-up & done. Jeff's website lists the 914 ones - http://bowlsby.net/914/Classic/Recalls.htm NHTSA Recall Look-up - https://www.nhtsa.gov/recalls . Cheers! (IMG:style_emoticons/default/beerchug.gif) Tom /////// |
dr914@autoatlanta.com HO campaign Aug 3 2018, 08:43 AM
sithot
What does HO stand for? :confused:
H.O. trains,... Aug 3 2018, 09:37 AM
sithot
Horrible out... Aug 3 2018, 09:43 AM
dr914@autoatlanta.com Tom is dead on, if your 914 has not had it done, t... Aug 3 2018, 11:29 AM
ejm
As Jeff said, it's the "HO Recall" ... Aug 3 2018, 08:12 PM
rhodyguy A little baking soda sprinkled on the bat tray wit... Aug 3 2018, 09:47 AM
Jeff Bowlsby You guyzzz.. :rolleyes:
HO is the 914 recall cam... Aug 3 2018, 10:08 AM
rhodyguy Nice jeff. 2 lugs with green paint. Who knew? Aug 3 2018, 10:22 AM
bbrock
Don't ge... Aug 3 2018, 10:30 AM
914Next
Don't g... Aug 4 2018, 08:01 AM
dr914@autoatlanta.com green slathered 914 alloy wheel lug nuts are a sig... Aug 4 2018, 08:32 AM
914Next
green slathered 914 alloy wheel lug nuts are a si... Aug 4 2018, 09:47 AM
dr914@autoatlanta.com we have them on the shelf, 111601173
[quote nam... Aug 4 2018, 09:59 AM
Jeff Bowlsby
George where can one buy the black lug covers?
... Aug 4 2018, 10:09 AM
dr914@autoatlanta.com Jeff is of course correct, as usual, in that they ... Aug 4 2018, 11:06 AM
Lucky9146
George can't catch a break so I will say i... Aug 3 2018, 11:04 AM
bbrock So back to this sticker. The placement seems wron... Aug 3 2018, 04:07 PM
dr914@autoatlanta.com SHOULD be on the battery cover, but never know wha... Aug 3 2018, 04:30 PM
bbrock
SHOULD be on the battery cover, but never know wh... Aug 3 2018, 07:23 PM
rhodyguy Those are beautiful wheels. Aug 4 2018, 08:09 AM
r_towle 914 HO you are! Aug 4 2018, 11:09 AM![]() ![]() |
Lo-Fi Version | Time is now: 7th October 2026 - 02:13 PM |
