> Holley EFI, Not just for American 4BBL carb replacements anymore...
horizontally-opposed
post Aug 2 2018, 11:33 AM
So I am hearing this is a very attractive setup for 4+ cylinder engines, and can be made to work with ITB setups for a flat six, such as PMO's. The 4BBL pricing sure is right, and it's said to be "self tuning" and a dream to work with/on.
Anyone have any experience of this, or know of a Porsche engine running it?
post Aug 2 2018, 11:09 PM
When I think about EFI, I like the idea of the "who" behind the system.
Any company can go out, but I put more stock in Holley or something like Andrew pointed out (the MS3 unit). I think about some of the old Haltech or other random systems, and trying to keep a 368 or 486 laptop going to support them.
Only way I'd do the Holley or MS3 is if I could use ITBs made for a flat six (i.e. PMOs). But the prices of these units are getting pretty interesting compared to Motec systems of not long ago—even the "budget" ganged four-cylinder Motec setups where you controlled a flat six like an inline three. Now we are seeing price points that make a conversion from a good, sellable set of 911 Webers pretty interesting.
It isn't a bad time to be a car enthusiast...
ConeDodger
post Aug 3 2018, 06:40 PM
Apex killer!
QUOTE(horizontally-opposed @ Aug 3 2018, 02:09 AM) *
Pete, I still recall our conversation a decade or so back at that drive-in in Napa Valley. You were right of course, the SDS system I used was only a bit better than a well tuned carb. Perhaps in its defense, it was controlling ITB’s that had massive vacuum fluctuations. Your argument, that the factory systems were so much more sophisticated was on my mind when I decided to go with the factory system on the 3.2 that ultimately found its way into my car.
I do think the MS3 described by Andyrew is a much more advanced system and it’s hard to believe SDS is in the same price range. I plan on using this system with the new engine I’m putting in my 240Z.
Mark Henry
post Aug 8 2018, 09:22 AM
that's what I do!
QUOTE(ConeDodger @ Aug 3 2018, 08:40 PM) *
QUOTE(ConeDodger @ Aug 4 2018, 02:56 PM) *
No one is criticizing the SDS support. It’s the function I was talking about. (IMG:style_emoticons/default/shades.gif)
Again I ask did you try TPS only? I already know the answer...you didn't.
IIRC your reply to this question was if it won't run proper in MAP it's not a good system.
So basically you're blaming SDS for your improper tuning and a bad engine/intake/cam choices for your expectations.
BTW I'm pretty sure I'm running the same cam you did.
The 3.2 with stock FI is a (IMG:style_emoticons/default/bs.gif) comparison, one is a stock (or near stock) engine and the other is is a hot cam, ITB, poor vacuum, double stock HP engine.
All aftermarket FI systems with ITB's, hot cams and therefore poor vacuum signals have issue with the MAP sensor.
MS is no different, same issue you have to run in what they call "alpha-N" which is exactly what SDS calls TPS only. MS does have an advantage in a single TB with hot cam app as you can help TPS (blend) with MAF sensor.
Running TPS only I've found only a few cons. In stop and go traffic below 3000rpm the engine has trouble at a steady speed. You have to slowly accelerate/decelerate or stay above 3000rpm.
You have to program in a TPS fuel cut or it backfires on deceleration.
The other is in TPS only you turn off altitude correction, exact same thing happens running MS in aplha-N, but the SDS has a rich/lean knob that can be used to easily correct this.
Other than that it runs great.
https://www.youtube.com/watch?v=r9Xmmf9G7Ns
https://www.youtube.com/watch?v=aaFf14DgUs8
ConeDodger
post Aug 8 2018, 10:57 AM
Apex killer!
QUOTE(Mark Henry @ Aug 8 2018, 12:22 PM) *
My apologies to those trying to learn from this thread. SDS was mentioned only because of a conversation I had with Pete about it on a BBQ/Tour day. It is pretty Stone Age compared to what is available now. Randall tried it in TPS and it was a compromise at best.
Although I autocross occasionally and do lots of track days, my car primarily sees street time. I can’t be bothered with rich/lean knobs and such. That’s great for aircraft which was originally the SDS target market, but there are just so many better systems now.
Sadly, I am sure Mark will keep pushing TPS and SDS and probably want us all to sing “Oh Canada.” He can’t help himself. It’s all he apparently knows. I know, that others who ran SDS in TPS couldn’t get it to run right in traffic. 10 years ago, I knew a dozen locals running SDS. All of them have moved on.
horizontally-opposed   Holley EFI   Aug 2 2018, 11:33 AM
Vacca Rabite   I know of a corvair 6 (in a bus) that was running ...   Aug 2 2018, 11:52 AM
Andyrew   I would much prefer MS3 Pro EVO. Im considering th...   Aug 2 2018, 01:29 PM
Chris914n6   I've been eyeballing one of these for Dads old...   Aug 2 2018, 08:07 PM
burton73   I've been eyeballing one of these for Dads ol...   Aug 2 2018, 08:15 PM
jd74914   For the 914n6 I've got my eye on [url=https:/...   Aug 3 2018, 08:33 AM
Andyrew   Companies like Haltech are still around and make...   Aug 3 2018, 09:56 AM
Andyrew   That Goefi is an awesome looking piece of hardware...   Aug 2 2018, 09:18 PM
horizontally-opposed   When I think about EFI, I like the idea of the ...   Aug 2 2018, 11:09 PM
ConeDodger   When I think about EFI, I like the idea of the ...   Aug 3 2018, 06:40 PM
Mark Henry   When I think about EFI, I like the idea of the ...   Aug 3 2018, 09:58 PM
Mark Henry   [quote name='horizontally-opposed' post='263...   Aug 8 2018, 09:22 AM
ConeDodger   [quote name='horizontally-opposed' post='26...   Aug 8 2018, 10:57 AM
Mark Henry   So this is for a /6? What is the cars use and your...   Aug 3 2018, 10:51 AM
914pipe   I'm going to experiment with Speeduino, that w...   Aug 3 2018, 07:59 PM
Mark Henry   I'm going to experiment with Speeduino, that ...   Aug 3 2018, 10:06 PM
914forme   I'm going to experiment with Speeduino, that...   Aug 4 2018, 11:34 AM
ConeDodger   [quote name='Mark Henry' post='2635263' date='Aug...   Aug 4 2018, 12:56 PM
914forme   No one is criticizing the SDS support. It’s the...   Aug 4 2018, 07:07 PM
Matty900   I am running a microsquirt (MS2) system with ITBs ...   Aug 3 2018, 10:15 PM
914four   Anyone using this Magasquirt package from the Dub ...   Aug 4 2018, 07:13 AM
horizontally-opposed   A number of good options. I would probably choose ...   Aug 4 2018, 02:18 PM
914pipe   A number of good options. I would probably choose...   Aug 4 2018, 11:10 PM
Andyrew   Ya but the Holley efi was essentially designed for...   Aug 5 2018, 12:30 AM
horizontally-opposed   Apparently, Holley recently released a system set ...   Aug 5 2018, 10:10 AM
Vacca Rabite   Meanwhile, threads like these are what has kept ...   Aug 7 2018, 12:51 PM
Travis Neff   Holley seems to have a few efi systems, which one ...   Aug 5 2018, 08:37 PM
horizontally-opposed   Holley seems to have a few efi systems, which one...   Aug 6 2018, 10:58 AM
Mueller   Chris Baker (tygaboy) is going to use the Holley H...   Aug 6 2018, 12:11 PM
ConeDodger   Chris Baker (tygaboy) is going to use the Holley ...   Aug 7 2018, 01:39 PM
Mueller   I worry about “Hot Rod and other V8 biased...   Aug 7 2018, 01:46 PM
jd74914   I worry about “Hot Rod and other V8 biased” m...   Aug 7 2018, 02:17 PM
horizontally-opposed   ^ It's a fair worry with some of those books. ...   Aug 7 2018, 03:43 PM
Chris914n6   The innovative stuff isn't going to come from ...   Aug 7 2018, 03:55 PM
burton73   For a GM V8 It looks like all the parts for the S...   Aug 7 2018, 04:13 PM
Mark Henry   Again I wasn't really hauling it as it's h...   Aug 8 2018, 10:22 AM
horizontally-opposed   Suspect we are turning a corner from aftermarket E...   Aug 8 2018, 11:01 AM
Mark Henry   Suspect we are turning a corner from aftermarket ...   Aug 8 2018, 12:21 PM
Mark Henry   What is your project? stock engine? rebuilt? good...   Aug 8 2018, 02:49 PM
Mueller   I saw this motor on Hemmings today, I bet one coul...   Aug 10 2018, 03:15 PM
mb911   I saw this motor on Hemmings today, I bet one cou...   Aug 11 2018, 06:56 AM
horizontally-opposed   I saw this motor on Hemmings today, I bet one cou...   Aug 11 2018, 08:04 AM
73-914   bet it doesn't run to well   Aug 10 2018, 03:48 PM
Mark Henry   You can get almost anything to work :) With lar...   Aug 11 2018, 08:34 AM
ottox914   My 2056 running SDS, big itb’s, a fairly large c...   Aug 11 2018, 10:40 PM
Mark Henry   Big lift isn't a problem, large duration and o...   Aug 12 2018, 06:25 AM
ottox914   Big lift isn't a problem, large duration and ...   Aug 12 2018, 09:35 PM
Mark Henry   Big lift isn't a problem, large duration and...   Aug 13 2018, 07:55 AM
ConeDodger   I saw the Holley system at the Big Boy Toy Store a...   Aug 12 2018, 09:11 AM
ConeDodger   For the record, I have never met Mark Henry. I hav...   Aug 13 2018, 12:31 PM
Mark Henry   Well my edumacaton is a lot higher than you think....   Aug 13 2018, 12:59 PM
Chris914n6   I'm glad SDS has been working for you, but it...   Aug 13 2018, 01:06 PM
Mark Henry   I'm glad SDS has been working for you, but it...   Aug 13 2018, 02:14 PM
Chris914n6   [quote name='Chris914n6' post='2638457' date='Aug...   Aug 13 2018, 04:15 PM
horizontally-opposed   ECUMaster black, MS3pro, and AEM Infinity particu...   Aug 13 2018, 06:24 PM
Mark Henry   [quote name='Chris914n6' post='2638457' date='Aug...   Aug 14 2018, 12:11 PM
- Lo-Fi Version Time is now: 1st August 2025 - 04:59 AM
