Not worth the $$$ .. ?, Building up the T4 VS the extra $$$ & work for a 6cyl |
Beakster |
Aug 8 2018, 10:04 AM
Member Group: Members Posts: 121 Joined: 13-August 15 From: Calgary,AB Canada Member No.: 19,055 Region Association: None |
There seems to be an ongoing debate about putting the money into building up a T4 4cyl engine to investing the extra time $$$ and the extra work involved in putting in a 6cyl in a 914 .. These 914's need enough basic restoring just to keep them road worthy then looking to add extra cost in non stock or easy engine swaps .. Every swap that isn't a type 4 seems to be a lot of extra $$$ .... Time....and Big Time WORK .. There are NO easy and affordable swaps on these cars .. (That I have ran into SO FAR ) It is getting harder and More expensive to track down good used parts for 914s especially the 2.0 heads .. Like a member had told me before I got the car Quote : There is no way you can budget in fixing up a 914 you will be always be battling $$$ VS Being satisfied ...
So it's (IMG:style_emoticons/default/welcome.png) I guess ... LOL |
mepstein |
Aug 8 2018, 01:22 PM
914-6 GT in waiting Group: Members Posts: 19,320 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Raby charges ~ $20K for one of his engines. Just buy the car and drop in a 3.2. Then you have something.
I wonder if that “912” has a 901 trans or they left in the 915. |
ClayPerrine |
Aug 8 2018, 01:31 PM
Life's been good to me so far..... Group: Admin Posts: 15,527 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
I wonder if that “912” has a 901 trans or they left in the 915. All 911/912e cars had a 915 trans starting 1972. The 912E has a bastardized 915 that will hook to the 215MM clutch used on the 914 2.0 motor. Different input shaft and throwout bearing arm. The rest is the same as any other 915. And it still shifts like (IMG:style_emoticons/default/stromberg.gif) |
mepstein |
Aug 8 2018, 01:48 PM
I wonder if that “912” has a 901 trans or they left in the 915. All 911/912e cars had a 915 trans starting 1972. The 912E has a bastardized 915 that will hook to the 215MM clutch used on the 914 2.0 motor. Different input shaft and throwout bearing arm. The rest is the same as any other 915. And it still shifts like (IMG:style_emoticons/default/stromberg.gif) This was the 1977 “912” that has a non original type 4. |
Lo-Fi Version | Time is now: 13th June 2024 - 04:44 AM |
