> 914-4 2L #3 rod bearing failure
Driver174
post Aug 8 2018, 11:50 PM
Rod bearings 1,2 & 4 look good, but #3 not so good. This engine has approximately ten race weekends sense it was rebuilt. Has anyone seen this issue?
Driver174
post Aug 8 2018, 11:55 PM
Pic of crank journal that doesn't look or feel much different from the other journals except for the marks left from the bearing material.Attached Image
Driver174   914-4 2L #3 rod bearing failure   Aug 8 2018, 11:50 PM
Driver174   Pic of crank journal that doesn't look or feel...   Aug 8 2018, 11:55 PM
Krieger   I have not taken apart a motor with that little ti...   Aug 8 2018, 11:55 PM
flyer86d   We had the same issue with our modified 1.7. With ...   Aug 9 2018, 04:52 AM
914Sixer   Are you using steel backed bearings? Aftermarket ...   Aug 9 2018, 05:43 AM
ClayPerrine   I have seen it in a street engine. That is the rod...   Aug 9 2018, 06:43 AM
stownsen914   Looks like an aftermarket rod in the pic at top? W...   Aug 9 2018, 06:59 AM
Racer Chris   Do you have any deep sump or tuna can? Do you main...   Aug 9 2018, 07:03 AM
Mark Henry   Do you have any deep sump or tuna can? Do you mai...   Aug 9 2018, 08:09 AM
worn   Do you have any deep sump or tuna can? Do you mai...   Aug 13 2018, 04:28 PM
Racer Chris   ... In such a situation, what happens to the main...   Aug 13 2018, 06:35 PM
GregAmy   :shudder: That's why I spent the coin for a d...   Aug 9 2018, 07:07 AM
stownsen914   Listen to what Racer Chris has to say - tons of ex...   Aug 9 2018, 07:31 AM
McMark   I'm late to the party, but I agree with Mark a...   Aug 9 2018, 09:51 AM
Driver174   It has the "tuna can" oil sump and an oi...   Aug 9 2018, 10:24 AM
brant   Is there any way to improve on your oil cooler sys...   Aug 9 2018, 10:31 AM
Driver174   I do believe adding more air exit area from the oi...   Aug 9 2018, 11:16 AM
brant   I do believe adding more air exit area from the o...   Aug 9 2018, 11:26 AM
Vacca Rabite   I do believe adding more air exit area from the o...   Aug 9 2018, 11:28 AM
brant   I would add that you need air flow under the car t...   Aug 9 2018, 11:44 AM
stownsen914   250 is a bit hot. You can easily drop the temp by ...   Aug 13 2018, 04:09 PM
Tbrown4x4   Lots more surface area on the mains too. Was ther...   Aug 13 2018, 09:57 PM
914werke   Aftermarket rods do not have an oil slinger slot ...   Aug 13 2018, 10:05 PM
yeahmag   Had this happen to my rod bearings twice even whil...   Aug 14 2018, 10:40 AM
Racer Chris   I think getting rid of the windage tray and keepin...   Aug 14 2018, 10:53 AM
Driver174   Lots more surface area on the mains too. Was the...   Aug 14 2018, 09:57 PM
Driver174   Had this happen to my rod bearings twice even whi...   Aug 14 2018, 10:09 PM
Racer Chris   I'm using Brad Penn as well in 20W50 viscosi...   Aug 15 2018, 05:26 AM
brant   You also need to run a synthetic Dino oil is goin...   Aug 15 2018, 06:51 AM
Driver174   Did a trial assembly tonight with new main bearing...   Aug 18 2018, 01:53 AM
- Lo-Fi Version Time is now: 17th November 2026 - 05:37 AM
