| Driver174 |
Aug 8 2018, 11:50 PM
Member ![]() ![]() Group: Members Posts: 122 Joined: 2-February 17 From: Nevada Member No.: 20,806 Region Association: None
| Driver174 |
Aug 9 2018, 10:24 AM
It has the "tuna can" oil sump and an oil cooler mounted in front trunk. The oil gets quite hot; I think I've seen 240-250 degrees on gage during races.
I asked the original engine builder if I should install an AccuSump, but he claims that he has many of these racing with just tuna can, and never had oiling problems. |
Driver174 914-4 2L #3 rod bearing failure Aug 8 2018, 11:50 PM
Driver174 Pic of crank journal that doesn't look or feel... Aug 8 2018, 11:55 PM
Krieger I have not taken apart a motor with that little ti... Aug 8 2018, 11:55 PM
flyer86d We had the same issue with our modified 1.7. With ... Aug 9 2018, 04:52 AM
914Sixer Are you using steel backed bearings? Aftermarket ... Aug 9 2018, 05:43 AM
ClayPerrine I have seen it in a street engine. That is the rod... Aug 9 2018, 06:43 AM
stownsen914 Looks like an aftermarket rod in the pic at top? W... Aug 9 2018, 06:59 AM
Racer Chris Do you have any deep sump or tuna can? Do you main... Aug 9 2018, 07:03 AM
Mark Henry
Do you have any deep sump or tuna can? Do you mai... Aug 9 2018, 08:09 AM
worn
Do you have any deep sump or tuna can? Do you mai... Aug 13 2018, 04:28 PM
Racer Chris
In such a situation, what happens to the main... Aug 13 2018, 06:35 PM
GregAmy :shudder:
That's why I spent the coin for a d... Aug 9 2018, 07:07 AM
stownsen914 Listen to what Racer Chris has to say - tons of ex... Aug 9 2018, 07:31 AM
McMark I'm late to the party, but I agree with Mark a... Aug 9 2018, 09:51 AM
brant Is there any way to improve on your oil cooler sys... Aug 9 2018, 10:31 AM
Driver174 I do believe adding more air exit area from the oi... Aug 9 2018, 11:16 AM
brant
I do believe adding more air exit area from the o... Aug 9 2018, 11:26 AM
Vacca Rabite
I do believe adding more air exit area from the o... Aug 9 2018, 11:28 AM
brant I would add that you need air flow under the car t... Aug 9 2018, 11:44 AM
stownsen914 250 is a bit hot. You can easily drop the temp by ... Aug 13 2018, 04:09 PM
Tbrown4x4 Lots more surface area on the mains too.
Was ther... Aug 13 2018, 09:57 PM
914werke Aftermarket rods do not have an oil slinger slot ... Aug 13 2018, 10:05 PM
yeahmag Had this happen to my rod bearings twice even whil... Aug 14 2018, 10:40 AM
Racer Chris I think getting rid of the windage tray and keepin... Aug 14 2018, 10:53 AM
Driver174
Was the... Aug 14 2018, 09:57 PM
Driver174
Had this happen to my rod bearings twice even whi... Aug 14 2018, 10:09 PM
Racer Chris
I'm using Brad Penn as well in 20W50 viscosi... Aug 15 2018, 05:26 AM
brant You also need to run a synthetic
Dino oil is goin... Aug 15 2018, 06:51 AM
Driver174 Did a trial assembly tonight with new main bearing... Aug 18 2018, 01:53 AM![]() ![]() |
Lo-Fi Version | Time is now: 17th November 2026 - 05:37 AM |
