> 914-4 2L #3 rod bearing failure
Driver174
post Aug 8 2018, 11:50 PM
Rod bearings 1,2 & 4 look good, but #3 not so good. This engine has approximately ten race weekends sense it was rebuilt. Has anyone seen this issue?
brant
post Aug 9 2018, 10:31 AM
Is there any way to improve on your oil cooler system?
when we used to race a -4.... We built 3 different cooler exits all using the same motor and same oil cooler....
we dropped the oil temp 10degrees F, each time we improved the cooler air exit
overall 25degree's just by ducting in the least restrictive way possible (through the hood)
sounds a little too hot to me
also if your not doing it.... change your oil after every event
you will notice a longer engine life for the efforts.
brant
Driver174   914-4 2L #3 rod bearing failure   Aug 8 2018, 11:50 PM
Driver174   Pic of crank journal that doesn't look or feel...   Aug 8 2018, 11:55 PM
Krieger   I have not taken apart a motor with that little ti...   Aug 8 2018, 11:55 PM
flyer86d   We had the same issue with our modified 1.7. With ...   Aug 9 2018, 04:52 AM
914Sixer   Are you using steel backed bearings? Aftermarket ...   Aug 9 2018, 05:43 AM
ClayPerrine   I have seen it in a street engine. That is the rod...   Aug 9 2018, 06:43 AM
stownsen914   Looks like an aftermarket rod in the pic at top? W...   Aug 9 2018, 06:59 AM
Racer Chris   Do you have any deep sump or tuna can? Do you main...   Aug 9 2018, 07:03 AM
Mark Henry   Do you have any deep sump or tuna can? Do you mai...   Aug 9 2018, 08:09 AM
worn   Do you have any deep sump or tuna can? Do you mai...   Aug 13 2018, 04:28 PM
Racer Chris   ... In such a situation, what happens to the main...   Aug 13 2018, 06:35 PM
GregAmy   :shudder: That's why I spent the coin for a d...   Aug 9 2018, 07:07 AM
stownsen914   Listen to what Racer Chris has to say - tons of ex...   Aug 9 2018, 07:31 AM
McMark   I'm late to the party, but I agree with Mark a...   Aug 9 2018, 09:51 AM
Driver174   It has the "tuna can" oil sump and an oi...   Aug 9 2018, 10:24 AM
brant   Is there any way to improve on your oil cooler sys...   Aug 9 2018, 10:31 AM
Driver174   I do believe adding more air exit area from the oi...   Aug 9 2018, 11:16 AM
brant   I do believe adding more air exit area from the o...   Aug 9 2018, 11:26 AM
Vacca Rabite   I do believe adding more air exit area from the o...   Aug 9 2018, 11:28 AM
brant   I would add that you need air flow under the car t...   Aug 9 2018, 11:44 AM
stownsen914   250 is a bit hot. You can easily drop the temp by ...   Aug 13 2018, 04:09 PM
Tbrown4x4   Lots more surface area on the mains too. Was ther...   Aug 13 2018, 09:57 PM
914werke   Aftermarket rods do not have an oil slinger slot ...   Aug 13 2018, 10:05 PM
yeahmag   Had this happen to my rod bearings twice even whil...   Aug 14 2018, 10:40 AM
Racer Chris   I think getting rid of the windage tray and keepin...   Aug 14 2018, 10:53 AM
Driver174   Lots more surface area on the mains too. Was the...   Aug 14 2018, 09:57 PM
Driver174   Had this happen to my rod bearings twice even whi...   Aug 14 2018, 10:09 PM
Racer Chris   I'm using Brad Penn as well in 20W50 viscosi...   Aug 15 2018, 05:26 AM
brant   You also need to run a synthetic Dino oil is goin...   Aug 15 2018, 06:51 AM
Driver174   Did a trial assembly tonight with new main bearing...   Aug 18 2018, 01:53 AM
- Lo-Fi Version Time is now: 17th November 2026 - 05:37 AM
