Measurements for 911 Flag Mirrors, outside measurements with mirrors on |
jim912928 |
Dec 3 2004, 11:36 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Well, I finally got around to taking some measurements. I did not take the mirrors off, but rather took measurements from 3 points on each door to the base of the rubber gasket. On this first picture...the key to the alignment is the yellow line...that line when looking at the car from the front should be vertical on both sides!
Also, for strength, you must use the 911 backing plate. I riveted mine on after having the holes cut in. Drivers side: Attached image(s) |
ahycaramba |
Aug 20 2016, 03:35 PM
“I live my life a quarter mile at a time.” Group: Members Posts: 161 Joined: 17-March 15 From: Murrieta, California Member No.: 18,534 Region Association: Southern California |
Hello friends,
To bring life back to this old topic... My question to you, if using the 993 mirror do you still use 911 & 944 flag mirror template to mount the 993 aero mirrors? (IMG:style_emoticons/default/idea.gif) Thanks Al |
Steve |
Aug 13 2018, 08:33 AM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Hello friends, To bring life back to this old topic... My question to you, if using the 993 mirror do you still use 911 & 944 flag mirror template to mount the 993 aero mirrors? (IMG:style_emoticons/default/idea.gif) Thanks Al I just switched from Aero mirrors to flag mirrors. The Aero mirrors looks good from certain angles, but look awkward from other angles, due to the squareness of the car. The Aero mirrors can use these same measurements, but note the Aero mirrors are more forgiving looks wise since they are not square. Flag mirrors have to be mounted flat and perfect or they look like crap. An Aero mirror can be angled up or slightly down and still look good. |
Lo-Fi Version | Time is now: 1st June 2024 - 10:54 PM |
