> 914-4 2L #3 rod bearing failure
Driver174
post Aug 8 2018, 11:50 PM
Rod bearings 1,2 & 4 look good, but #3 not so good. This engine has approximately ten race weekends sense it was rebuilt. Has anyone seen this issue?
brant
post Aug 9 2018, 11:44 AM
I would add that you need air flow under the car to benefit or assist in pulling the hot air out of the cooler when you go down
I used to run the really low rubber lip spoiler on the front
found that by using a less deep front spoiler (LE style) I could improve cooling.
so if your car is really low or has a front splitter... try letting more air run under the car by removing the front spoiler and that can also help with oil cooling.
stownsen914
post Aug 13 2018, 04:09 PM
250 is a bit hot. You can easily drop the temp by making sure you have proper ducting to and from the cooler. Make sure the air that enters your duct to the cooler has no where to go except through the cooler. Don't leave gaps or openings - the air will go there instead of through your cooler. Foam weather stripping works well to take up the gaps. Also, the opening in your bumper can be the size of the cooler or even a little smaller. It may be tempting to make it larger, but that won't work - it will just prevent air from going in.
On the air exit, through the hood is a good way. Wheel wells can also work if you don't want to cut the hood. Make sure the exit is at least as large as the cooler. A little larger is better.
Another thing - hopefully you used -10 or -12 oil lines. I've seen -8 used, but that's a bit too small and could restrict oil flow.
Driver174   914-4 2L #3 rod bearing failure   Aug 8 2018, 11:50 PM
Driver174   Pic of crank journal that doesn't look or feel...   Aug 8 2018, 11:55 PM
Krieger   I have not taken apart a motor with that little ti...   Aug 8 2018, 11:55 PM
flyer86d   We had the same issue with our modified 1.7. With ...   Aug 9 2018, 04:52 AM
914Sixer   Are you using steel backed bearings? Aftermarket ...   Aug 9 2018, 05:43 AM
ClayPerrine   I have seen it in a street engine. That is the rod...   Aug 9 2018, 06:43 AM
stownsen914   Looks like an aftermarket rod in the pic at top? W...   Aug 9 2018, 06:59 AM
Racer Chris   Do you have any deep sump or tuna can? Do you main...   Aug 9 2018, 07:03 AM
Mark Henry   Do you have any deep sump or tuna can? Do you mai...   Aug 9 2018, 08:09 AM
worn   Do you have any deep sump or tuna can? Do you mai...   Aug 13 2018, 04:28 PM
Racer Chris   ... In such a situation, what happens to the main...   Aug 13 2018, 06:35 PM
GregAmy   :shudder: That's why I spent the coin for a d...   Aug 9 2018, 07:07 AM
stownsen914   Listen to what Racer Chris has to say - tons of ex...   Aug 9 2018, 07:31 AM
McMark   I'm late to the party, but I agree with Mark a...   Aug 9 2018, 09:51 AM
Driver174   It has the "tuna can" oil sump and an oi...   Aug 9 2018, 10:24 AM
brant   Is there any way to improve on your oil cooler sys...   Aug 9 2018, 10:31 AM
Driver174   I do believe adding more air exit area from the oi...   Aug 9 2018, 11:16 AM
brant   I do believe adding more air exit area from the o...   Aug 9 2018, 11:26 AM
Vacca Rabite   I do believe adding more air exit area from the o...   Aug 9 2018, 11:28 AM
brant   I would add that you need air flow under the car t...   Aug 9 2018, 11:44 AM
stownsen914   250 is a bit hot. You can easily drop the temp by ...   Aug 13 2018, 04:09 PM
Tbrown4x4   Lots more surface area on the mains too. Was ther...   Aug 13 2018, 09:57 PM
914werke   Aftermarket rods do not have an oil slinger slot ...   Aug 13 2018, 10:05 PM
yeahmag   Had this happen to my rod bearings twice even whil...   Aug 14 2018, 10:40 AM
Racer Chris   I think getting rid of the windage tray and keepin...   Aug 14 2018, 10:53 AM
Driver174   Lots more surface area on the mains too. Was the...   Aug 14 2018, 09:57 PM
Driver174   Had this happen to my rod bearings twice even whi...   Aug 14 2018, 10:09 PM
Racer Chris   I'm using Brad Penn as well in 20W50 viscosi...   Aug 15 2018, 05:26 AM
brant   You also need to run a synthetic Dino oil is goin...   Aug 15 2018, 06:51 AM
Driver174   Did a trial assembly tonight with new main bearing...   Aug 18 2018, 01:53 AM
- Lo-Fi Version Time is now: 17th November 2026 - 05:37 AM
