Seam Seal - between caul and fender, Before I paint |
ruby914 |
Aug 14 2018, 01:59 AM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
It looks like both front fenders were replaced at some time in my cars life.
I can't say they did a bad job but they never replaced the seam seal. Originally was there a bead of seam seal at the bottom of this gap between the caul and fender? The 3 mm gap narrows to about 1 mm at the bottom. I am thinking I should fill that 1 mm gap. The way it is now water can drip thru in areas. I am not sure if that is a good thing or bad. (IMG:style_emoticons/default/confused24.gif) Attached thumbnail(s) |
DRPHIL914 |
Aug 14 2018, 08:45 AM
Dr. Phil Group: Members Posts: 5,768 Joined: 9-December 09 From: Bluffton, SC Member No.: 11,106 Region Association: South East States |
Fender was not replaced, the gap is normal and would have that seal in there like Noel said. You can clean out that channel and make sure its clean then epoxy primer and sealer, but not seam sealer, then the rubber seal.
Lo-Fi Version | Time is now: 10th June 2024 - 11:45 AM |
