QUOTE(SirAndy @ Aug 15 2018, 09:35 AM)
QUOTE(ruby914 @ Aug 15 2018, 01:27 AM)
Problem is they seam sealed this weep hole shut from the bottom side
I don't think this is a weep hole. On my car that part is brazed shut with what i assume is factory brazing. No hole there ...
Interesting. I just got back to my car and with out the ton of seam seal the joint really looks to function so water will not puddle under the rubber seal. My car is a 73. My car was not brazed but welded on the Aft end. Assuming my car is in no way factory work. Drivers side is very clean and and open up to the weld. So clean on the underside it looks like they didn't finish spot or tack welding it. The metal is set back so a weal weld is not possible. The passenger side, I put the epoxy primer in years ago, looks like it had one more tack weld. But still a clear path for water.
With this I was steering back away from sealing water tight.
It the words of Strawman "If memory serves, it was a factory goober/snot weld that tied those two pieces together... not a traditional pinch/spot weld."
I came back to ask the world about the factory seam seal on the underside.
If the seal is only below the horizontal pinch weld, water will pass thru.
If seal is on top it, fills that passage.
I looked at a 914 6 the other day. I think, it had seal top and bottom. But again, not factory work. SirAndy, yours is brazed front to back without the "ton" of seam seal on top of that?
