Seam Seal - between caul and fender, Before I paint |
ruby914 |
Aug 14 2018, 01:59 AM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
It looks like both front fenders were replaced at some time in my cars life.
I can't say they did a bad job but they never replaced the seam seal. Originally was there a bead of seam seal at the bottom of this gap between the caul and fender? The 3 mm gap narrows to about 1 mm at the bottom. I am thinking I should fill that 1 mm gap. The way it is now water can drip thru in areas. I am not sure if that is a good thing or bad. (IMG:style_emoticons/default/confused24.gif) Attached thumbnail(s) |
Mikey914 |
Aug 14 2018, 03:08 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Pretty normal to remove these. The OEM were a PVC, we madevours out of rubber tight enough you can push in with some hand soap. You can also easily remove and reinstall if you wish.
https://shop.914rubber.com/914-Fender-to-co...m?categoryId=-1 Attached thumbnail(s) |
Lo-Fi Version | Time is now: 9th June 2024 - 10:23 PM |
