> Any clues as to engine size?
Tdskip
post Aug 15 2018, 05:02 PM
Hi guys-hope everybody's having a good day. I was fortunate off to get a ton of help from Forest and Keith today getting the "turbo" clutch issue sorted out. I can't say enough about how helpful they were and gracious with their time.
One of the things that I suspected, but it appears we now have proof of, is that this engine was built up from the original 2.0 GC case spec.
Can anyone identify these heads or help make a guess as to displaceme
jcd914
post Aug 15 2018, 05:39 PM
You can't tell engine displacement from pictures of the heads.
If you had the right pictures someone could ID the heads but that doesn't really tell you much.
Anyone could use any heads (1.7, 1.8 or 2.0) to build any size engine.
For 914 heads, 1.7 & 1.8 heads have 4 intake studs and 2.0 heads have 3 intake studs.
On 1.7 & 1.8 heads the spark plug holes are angled up more than 2.0 heads.
Those are the prominent visual differences between the heads.
Pistons and crank are what change the displacement and you can't see them with the engine assembled.
If you have a GC case and 3 stud heads you probably have a 2.0 engine at least.
It is common to put bigger pistons and cylinders on as part of a rebuild, so who knows what is under the cylinder head.
Jim
Tdskip
post Aug 15 2018, 05:41 PM
QUOTE(jcd914 @ Aug 15 2018, 06:39 PM) *
Jim
And thanks Jim-was hoping that maybe there was something distinctive about the size of the fins and material etc. that would jump out.
Appreciate the response
Tdskip   Any clues as to engine size?   Aug 15 2018, 05:02 PM
Tdskip   RE: Any clues as to engine size?   Aug 15 2018, 05:03 PM
mepstein   Guess displacement with a picture!   Aug 15 2018, 05:08 PM
Tdskip   Guess displacement with a picture! Yep - th...   Aug 15 2018, 05:23 PM
mepstein   Guess displacement with a picture! Yep - t...   Aug 15 2018, 05:45 PM
jcd914   You can't tell engine displacement from pictur...   Aug 15 2018, 05:39 PM
Tdskip   You can't tell engine displacement from pictu...   Aug 15 2018, 05:41 PM
Spoke   I've heard you can measure the stroke with a c...   Aug 15 2018, 06:16 PM
Rand   I've heard you can measure the stroke with a ...   Aug 15 2018, 06:40 PM
Vacca Rabite   I've heard you can measure the stroke with a ...   Aug 16 2018, 09:45 AM
ClayPerrine   I've heard you can measure the stroke with a ...   Aug 16 2018, 10:58 AM
Larmo63   Let's ask Carnac............   Aug 15 2018, 06:25 PM
forrestkhaag   As you and everyone else can read into this thread...   Aug 15 2018, 06:38 PM
Tdskip   As you and everyone else can read into this threa...   Aug 15 2018, 11:14 PM
forrestkhaag   If OGeez are Old Jesus freaks, Yes. Thou Shall app...   Aug 15 2018, 06:41 PM
Cracker   Going out on a limb here but I suppose it is no le...   Aug 16 2018, 07:31 AM
Tdskip   Going out on a limb here but I suppose it is no l...   Aug 16 2018, 09:20 AM
ValcoOscar   Tom- From all the replies it appears you have a s...   Aug 16 2018, 09:31 AM
bretth   Interesting looking cylinders, definitely not cast...   Aug 16 2018, 10:39 AM
Mark Henry   Interesting looking cylinders, definitely not cas...   Aug 16 2018, 12:09 PM
Mueller   Put cylinder 1 at BDC, fill with liquid, measure h...   Aug 16 2018, 11:14 AM
Dave_Darling   The cylinders don't look like cast iron. Chan...   Aug 16 2018, 11:49 AM
brant   There is a test that is used by race organizations...   Aug 16 2018, 01:21 PM
- Lo-Fi Version Time is now: 13th September 2026 - 06:56 AM
