| Tdskip |
Aug 15 2018, 05:02 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,783 Joined: 1-December 17 From: soCal Member No.: 21,666 Region Association: None
Hi guys-hope everybody's having a good day. I was fortunate off to get a ton of help from Forest and Keith today getting the "turbo" clutch issue sorted out. I can't say enough about how helpful they were and gracious with their time.
One of the things that I suspected, but it appears we now have proof of, is that this engine was built up from the original 2.0 GC case spec. Can anyone identify these heads or help make a guess as to displaceme Attached thumbnail(s) |
| forrestkhaag |
Aug 15 2018, 06:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 935 Joined: 21-April 14 From: Scottsdale, Arizona Member No.: 17,273 Region Association: Southwest Region |
As you and everyone else can read into this thread is that your question, while well intended and well focused on available investigations today, cannot define what you have in detail.
Having been under there for a few hours today, I would say (as your pictures indicate) that you have a very substantial 4 - built on a 2.0 case - and it doesn't leak at the case, cylinders, or heads or even pesky valve covers. PR tubes are another thing but an easy fix. So all is good for now and it is a safe bet it will serve you for a few thousand miles. But. Is it safe?.......... On your current track, you have ample time to sort out what the engine is. You have a nice backup 4 - 2.0 and working tranny to match / if things go North and crap-out. (I'm from the South) What you know it is,... is.... (the meaning of is is?,.) is you have a strong well built 4 above 2.0 based on the performance you report on first drives / and you have a 912 and another 914-4 so lets just keep on the track of getting the clutch repaired/replaced and get it on the road for a few thousand miles. I think it is safe.... Yes. Its safe. Then we can dabble in what is is .......... (IMG:style_emoticons/default/beerchug.gif) see you at 10 under the lift.a Attached image(s)
Tdskip Any clues as to engine size? Aug 15 2018, 05:02 PM
Tdskip RE: Any clues as to engine size? Aug 15 2018, 05:03 PM
mepstein Guess displacement with a picture! Aug 15 2018, 05:08 PM
Tdskip
Yep - th... Aug 15 2018, 05:23 PM
Yep - t... Aug 15 2018, 05:45 PM
jcd914 You can't tell engine displacement from pictur... Aug 15 2018, 05:39 PM
Tdskip
You can't tell engine displacement from pictu... Aug 15 2018, 05:41 PM
Spoke I've heard you can measure the stroke with a c... Aug 15 2018, 06:16 PM
Rand
I've heard you can measure the stroke with a ... Aug 15 2018, 06:40 PM
Vacca Rabite
I've heard you can measure the stroke with a ... Aug 16 2018, 09:45 AM
ClayPerrine
I've heard you can measure the stroke with a ... Aug 16 2018, 10:58 AM
Larmo63 Let's ask Carnac............
Aug 15 2018, 06:25 PM
Tdskip
As you and everyone else can read into this threa... Aug 15 2018, 11:14 PM
forrestkhaag If OGeez are Old Jesus freaks, Yes. Thou Shall app... Aug 15 2018, 06:41 PM
Cracker Going out on a limb here but I suppose it is no le... Aug 16 2018, 07:31 AM
Tdskip
Going out on a limb here but I suppose it is no l... Aug 16 2018, 09:20 AM
ValcoOscar Tom-
From all the replies it appears you have a s... Aug 16 2018, 09:31 AM
bretth Interesting looking cylinders, definitely not cast... Aug 16 2018, 10:39 AM
Mark Henry
Interesting looking cylinders, definitely not cas... Aug 16 2018, 12:09 PM
Mueller Put cylinder 1 at BDC, fill with liquid, measure h... Aug 16 2018, 11:14 AM
Dave_Darling The cylinders don't look like cast iron. Chan... Aug 16 2018, 11:49 AM
brant There is a test that is used by race organizations... Aug 16 2018, 01:21 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th September 2026 - 06:57 AM |
