Seam Seal - between caul and fender, Before I paint |
ruby914 |
Aug 14 2018, 01:59 AM
Senior Member Group: Members Posts: 720 Joined: 26-April 09 From: Hawthorne, Ca Member No.: 10,305 Region Association: None |
It looks like both front fenders were replaced at some time in my cars life.
I can't say they did a bad job but they never replaced the seam seal. Originally was there a bead of seam seal at the bottom of this gap between the caul and fender? The 3 mm gap narrows to about 1 mm at the bottom. I am thinking I should fill that 1 mm gap. The way it is now water can drip thru in areas. I am not sure if that is a good thing or bad. (IMG:style_emoticons/default/confused24.gif) Attached thumbnail(s) |
ruby914 |
Aug 16 2018, 10:14 AM
Thanks Matty any photos would be great.
So to fill or not to fill? Epoxy is good to seal but not to fill a large flexible gaps that have been called an expansion joints. So if I was to fill this joint, I think epoxy covered with a flexible seam seal would be best. I have a SEM seal tube that has a very small tip that may get down to fill this area neatly. Attached image(s) |
Lo-Fi Version | Time is now: 9th June 2024 - 04:42 PM |
