| Mark Henry |
Aug 18 2018, 09:08 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
I'm going to try Euromeister 17 x 7" (ET23) on narrow body, because I found a pair here in Canada for cheap, saves me about $200 of importing a full set.
Just wondering how they fit, from a tire calculater it seems with a 205/50-17 tire it will only push the tire out less than a 1/4" more than the 205/60-15's I now have. If that's all it is they should fit my rear fenders with no mod or just a slight roll of the rear part of the lip. I really like the look of the 15" fuchs with 205/60-15 tires, but the all season passenger car tires I have just plain suck. The pro is 17" tires are cheap and you have a good selection of performance tires. The con is I've never cared for the big rim baby buggy look. It just doesn't work for me on a vintage 914. The other con is they're not real and heavier. But someone posted a set where they painted the lip black creating a faux higher side wall look that I really liked. I've tried searching to find this pic but have had no luck, hopefully the member will see this and repost the pic. |
| Chris914n6 |
Aug 18 2018, 07:36 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,527 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
15x7 Fuchs are et23. Cookies are 15x7 et23. A 205 tire is pretty much 205 wide at the tread. So why doesn't the 17x7 et23 fit with a little rolling????
My 225/50 on 16x7 et40 +15mm spacer Boxsters fit great with DD's autox alignment. Then I bought an Eastwood tool and rolled the (IMG:style_emoticons/default/stromberg.gif) out of them that looks like they'll fit a 235-245. |
| DRPHIL914 |
Aug 18 2018, 08:52 PM
Dr. Phil ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,892 Joined: 9-December 09 From: Kennesaw, GA Member No.: 11,106 Region Association: South East States
15x7 Fuchs are et23. Cookies are 15x7 et23. A 205 tire is pretty much 205 wide at the tread. So why doesn't the 17x7 et23 fit with a little rolling???? My 225/50 on 16x7 et40 +15mm spacer Boxsters fit great with DD's autox alignment. Then I bought an Eastwood tool and rolled the (IMG:style_emoticons/default/stromberg.gif) out of them that looks like they'll fit a 235-245. i have stocke 16” fuchs, and we put 205/55 on them, have been rolled ans still rubbed and blistered paint, went thru a lot to make fenders look like new after someone made a huge mess of my fenders- these do now fit but still so close that with a new paint jobi am not chancing it- - answer to your question is some may make it due to variation in the cars since they were hand made. i had more room on one side than the other. i had 3 choices- 1. use 944 wheels- they go in just under1/2” on inside and outside and give you enough room with 205’s- 2. use a 195 tire in that same brand to get a slightly smaller tread width , i would have had 1/4 more room on outside , OR 3. use a tire brand that is not as wide- not all 205 tires are the same!. I opted for a 4th choice, keep my 205/55 Bridgestone potenza and put them on a 16x6 fuchs, same as front- . also as stated by another, you could increase your camber - i have a stock set up but if i increased this it may have fiven me the safe clearance i wanted with my 7” rims- just dont have thr time to sort thst all out or the $$ to spend on changing tires etc- i already have the set of 6’s |
| Chris914n6 |
Aug 18 2018, 10:56 PM
15x7 Fuchs are et23. Cookies are 15x7 et23. A 205 tire is pretty much 205 wide at the tread. So why doesn't the 17x7 et23 fit with a little rolling???? My 225/50 on 16x7 et40 +15mm spacer Boxsters fit great with DD's autox alignment. Then I bought an Eastwood tool and rolled the (IMG:style_emoticons/default/stromberg.gif) out of them that looks like they'll fit a 235-245. also as stated by another, you could increase your camber - i have a stock set up but if i increased this it may have fiven me the safe clearance i wanted with my 7” rims- just dont have thr time to sort thst all out or the $$ to spend on changing tires etc- i already have the set of 6’s That was me too, and I told you a long time ago on your thread to just tweak the camber and be done with it, but... |
Mark Henry Euromeister 17 x 7 fuchs on narrow body Aug 18 2018, 09:08 AM
dr914@autoatlanta.com 17 by seven will fit if they have the correct offs... Aug 18 2018, 10:11 AM
Mark Henry The big questions I have is if anyone who's do... Aug 18 2018, 11:40 AM
sixnotfour
The big questions I have is if anyone who's d... Aug 18 2018, 12:23 PM
Mark Henry
[quote name='Mark Henry' post='2640062' date='Aug... Aug 18 2018, 12:46 PM
dr914@autoatlanta.com no 23 will not fit under stock wells
The big qu... Aug 18 2018, 01:41 PM
horizontally-opposed Yep! Been done...
http://forums.pelicanparts.... Aug 18 2018, 11:48 AM
sixnotfour L have 2 sets of the 5lugs ,,one with 205/45 and o... Aug 18 2018, 11:52 AM
sixnotfour these are et 40 also ..
https://www.carid.com/kla... Aug 18 2018, 12:31 PM
Chris914n6 Long story deleted.... you will be fine, maybe nee... Aug 18 2018, 01:00 PM
Mark Henry Dang I thought 020 was ET20 but turns out stock 15... Aug 18 2018, 01:08 PM
horizontally-opposed Sorry missed the key "narrow body" part,... Aug 18 2018, 01:24 PM
sixnotfour CIP 1 has em, L bought my 2 sets off SAMBA as the ... Aug 18 2018, 01:41 PM
Mark Henry Dang :( I hate reneging on a deal, but money hasn... Aug 18 2018, 04:20 PM
Spoke Euromeister 7x17 on the front and 9x17 on the rear... Aug 18 2018, 08:16 PM
SO.O.C914er Damn that badpnny car is bad ass. I like everythin... Aug 18 2018, 11:35 PM![]() ![]() |
Lo-Fi Version | Time is now: 17th March 2026 - 07:25 PM |
