| Bartlett 914 |
Oct 8 2010, 12:13 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,219 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I have a relay board that was giving me grief. Several times the car would not start. Cleaning the fuse seemed to help but once in a great while the problem returned. The problem was the fuse holder. As these connections get dirty, they heat up. The problem in my case was aggravated by the use of the heater fan. This draws more current and made the problem of the fuse heating worse. I have some before and after pictures. You can see how the fuse holder is leaning back. If you look closer, you can see melted plastic where it is mounted. My solution was to install a new fuse holder. I recently installed an Engman fuse panel so now all my fuses will be the newer style. No more VW fuses! Te resin I used was Vagabond Model-cast 3521S black. This stuff flows like water and dries pretty fast. It is hard when cured and looks real nice. The biggest problem is the resin flowing through the board and leaking. I knew this would happen and I taped where I thought it would leak out. I missed the voltage regulator socket. It looked fine from the rear but it leaked real bad. I had quite a time sealing this up. If you do this, try epoxy first to seal where the pins come through.
| Bartlett 914 |
Oct 8 2010, 12:15 PM
kjyf
| VaccaRabite |
Aug 21 2018, 07:17 AM
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,936 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region
kjyf Hey, I know this is an old thread, but I may need to renue my board. How did you get up all the old potting? I know you said you hit everything with a little glass bead, but did you do any testing of the relay board to make sure all the connections were solid? Zach |
| Bartlett 914 |
Aug 21 2018, 08:06 AM
kjyf Hey, I know this is an old thread, but I may need to renue my board. How did you get up all the old potting? I know you said you hit everything with a little glass bead, but did you do any testing of the relay board to make sure all the connections were solid? Zach Good news and bad news here. I still have that board. I came out great looking and worked awhile but the old issue came back. I replaced it and I never went back to see exactly where the issue is. I suspect there is a bad connection with the buss bars and probably a relay socket pin. I have heard that these should be soldered first and then the epoxy installed. Now that this has been done, it is too late for mine. I consider the board to be not repairable at this time. The epoxy was from Smooth-on. If someone does this there is a problem with the epoxy running through where relay connections are located. Make extra sure these holes are plugged somehow. |
| porschetub |
Aug 21 2018, 11:15 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,198 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
kjyf Hey, I know this is an old thread, but I may need to renue my board. How did you get up all the old potting? I know you said you hit everything with a little glass bead, but did you do any testing of the relay board to make sure all the connections were solid? Zach Good news and bad news here. I still have that board. I came out great looking and worked awhile but the old issue came back. I replaced it and I never went back to see exactly where the issue is. I suspect there is a bad connection with the buss bars and probably a relay socket pin. I have heard that these should be soldered first and then the epoxy installed. Now that this has been done, it is too late for mine. I consider the board to be not repairable at this time. The epoxy was from Smooth-on. If someone does this there is a problem with the epoxy running through where relay connections are located. Make extra sure these holes are plugged somehow. Seems when they are shite they don't work again after TLC mine was no better and still had a dead pump feed,got a reconditioned unit from a very good seller on here and all is well. |
Bartlett 914 Relay board repair Oct 8 2010, 12:13 PM
Vacca Rabite
Seems when they are shite they don't work ag... Aug 22 2018, 08:00 AM
Bartlett 914
Seems when they are shite they don't work a... Aug 22 2018, 08:33 AM
Vacca Rabite
I really wished I had soldered the connections. ... Aug 23 2018, 11:08 AM
Bartlett 914
I really wished I had soldered the connections.... Aug 23 2018, 03:18 PM
bbrock
[quote name='Bartlett 914' post='1380640' date='O... Aug 21 2018, 08:16 AM
914_teener
kjyf
Hey, I know this is an old thread, but I ... Aug 21 2018, 09:21 AM
bbrock
soldered all the riveted connectiions.
Great ... Aug 21 2018, 09:42 AM
Drums66 ..Came out decent... :shades2:
what did you use o... Oct 8 2010, 12:21 PM
Bartlett 914
what did you use ... Oct 8 2010, 12:38 PM
Drums66 ...Excellent...thank you for the reply sir :shades... Oct 8 2010, 03:02 PM
MarkV I thought about soldering but wasn't sure I ha... Aug 21 2018, 08:15 PM
Bartlett 914
I thought about soldering but wasn't sure I h... Aug 21 2018, 09:23 PM
Bartlett 914 Well Zach got me interested in this board again. I... Aug 23 2018, 06:43 PM
DTMLGND Hi! I just acquired my ‘74 2.0 a few months ... Dec 16 2018, 01:36 AM
930cabman Again?
I am addressing the relay board and do no... May 28 2021, 03:12 PM
914-VI
Again?
I am addressing the relay board and do n... Jun 8 2021, 08:48 AM
914-VI
Again?
I am addressing the relay board and do ... Jun 8 2021, 08:59 AM
Olympic 914 I have used multiple coats of rubberized undercoat... May 29 2021, 06:31 AM
930cabman It will work for sure, you can make boats out of t... Jun 8 2021, 09:51 AM
GeorgeKopf I will be doing this shortly. Now is the time sin... Jun 29 2021, 08:01 PM![]() ![]() |
Lo-Fi Version | Time is now: 10th November 2026 - 07:39 AM |
