Relay board repair, How I did mine |
Bartlett 914 |
Oct 8 2010, 12:13 PM
Advanced Member Group: Members Posts: 2,216 Joined: 30-August 05 From: South Elgin IL Member No.: 4,707 Region Association: Upper MidWest |
I have a relay board that was giving me grief. Several times the car would not start. Cleaning the fuse seemed to help but once in a great while the problem returned. The problem was the fuse holder. As these connections get dirty, they heat up. The problem in my case was aggravated by the use of the heater fan. This draws more current and made the problem of the fuse heating worse. I have some before and after pictures. You can see how the fuse holder is leaning back. If you look closer, you can see melted plastic where it is mounted. My solution was to install a new fuse holder. I recently installed an Engman fuse panel so now all my fuses will be the newer style. No more VW fuses! Te resin I used was Vagabond Model-cast 3521S black. This stuff flows like water and dries pretty fast. It is hard when cured and looks real nice. The biggest problem is the resin flowing through the board and leaking. I knew this would happen and I taped where I thought it would leak out. I missed the voltage regulator socket. It looked fine from the rear but it leaked real bad. I had quite a time sealing this up. If you do this, try epoxy first to seal where the pins come through.
Attached image(s) |
Bartlett 914 |
Oct 8 2010, 12:15 PM
kjyf
Attached image(s) |
VaccaRabite |
Aug 21 2018, 07:17 AM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
kjyf Hey, I know this is an old thread, but I may need to renue my board. How did you get up all the old potting? I know you said you hit everything with a little glass bead, but did you do any testing of the relay board to make sure all the connections were solid? Zach |
Bartlett 914 |
Aug 21 2018, 08:06 AM
kjyf Hey, I know this is an old thread, but I may need to renue my board. How did you get up all the old potting? I know you said you hit everything with a little glass bead, but did you do any testing of the relay board to make sure all the connections were solid? Zach Good news and bad news here. I still have that board. I came out great looking and worked awhile but the old issue came back. I replaced it and I never went back to see exactly where the issue is. I suspect there is a bad connection with the buss bars and probably a relay socket pin. I have heard that these should be soldered first and then the epoxy installed. Now that this has been done, it is too late for mine. I consider the board to be not repairable at this time. The epoxy was from Smooth-on. If someone does this there is a problem with the epoxy running through where relay connections are located. Make extra sure these holes are plugged somehow. |
porschetub |
Aug 21 2018, 11:15 PM
Advanced Member Group: Members Posts: 4,703 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
kjyf Hey, I know this is an old thread, but I may need to renue my board. How did you get up all the old potting? I know you said you hit everything with a little glass bead, but did you do any testing of the relay board to make sure all the connections were solid? Zach Good news and bad news here. I still have that board. I came out great looking and worked awhile but the old issue came back. I replaced it and I never went back to see exactly where the issue is. I suspect there is a bad connection with the buss bars and probably a relay socket pin. I have heard that these should be soldered first and then the epoxy installed. Now that this has been done, it is too late for mine. I consider the board to be not repairable at this time. The epoxy was from Smooth-on. If someone does this there is a problem with the epoxy running through where relay connections are located. Make extra sure these holes are plugged somehow. Seems when they are shite they don't work again after TLC mine was no better and still had a dead pump feed,got a reconditioned unit from a very good seller on here and all is well. |
VaccaRabite |
Aug 22 2018, 08:00 AM
Seems when they are shite they don't work again after TLC mine was no better and still had a dead pump feed,got a reconditioned unit from a very good seller on here and all is well. Its a fairly simple board. The idea for cleaning and soldering all the rivets is a good one, as well as checking resistance from pin to pin. If there is a break in the copper somewhere, or corrosion, it should become apparent with a resistance test. If the VR that should be arriving today does not fix my charging system issues, I'm going to pull the board and try to rehab it over the weekend. Zach |
Bartlett 914 |
Aug 22 2018, 08:33 AM
Seems when they are shite they don't work again after TLC mine was no better and still had a dead pump feed,got a reconditioned unit from a very good seller on here and all is well. Its a fairly simple board. The idea for cleaning and soldering all the rivets is a good one, as well as checking resistance from pin to pin. If there is a break in the copper somewhere, or corrosion, it should become apparent with a resistance test. If the VR that should be arriving today does not fix my charging system issues, I'm going to pull the board and try to rehab it over the weekend. Zach I really wished I had soldered the connections. I should pick out an old board and see how difficult it will be. Glass bead blasting the copper will help in the soldering as will a good rosin flux (no acid flux). I think with good clean surface to start, it may solder fine. The epoxy is intended to keep atmosphere from corroding the connections. Now that the one I did has been epoxied I will need to wait another 40 years for it to crack out so I can solder it LOL |
VaccaRabite |
Aug 23 2018, 11:08 AM
I really wished I had soldered the connections. I should pick out an old board and see how difficult it will be. Glass bead blasting the copper will help in the soldering as will a good rosin flux (no acid flux). I think with good clean surface to start, it may solder fine. The epoxy is intended to keep atmosphere from corroding the connections. Now that the one I did has been epoxied I will need to wait another 40 years for it to crack out so I can solder it LOL I started stripping mine out last night. Looks straight forward. Of course now that I have 90% of the potting removed, I'm learning that I probably needn't have bothered, and my board was fine as is. Zach |
Lo-Fi Version | Time is now: 2nd June 2024 - 12:42 AM |
