| DennisO |
Aug 26 2018, 11:47 AM
Member ![]() ![]() Group: Members Posts: 61 Joined: 9-June 17 From: Clayton, NC Member No.: 21,162 Region Association: South East States
Hi All,
I finally had time to get back to my '75 project after life kept getting in the way :-) I have about 95% of the car disassembled and have a pretty good idea of all the rust and hidden damage. The floor pans have some surface rust and a couple of spots that might need a patch (eg by brake/clutch pedals). However, the floor inside the tunnel has some pretty good rust that must be dealt with. Odd, but it look like water leaked just inside the tunnel and sat. Is there a good way to remove the tunnel to access the floor underneath? This is probably not a good idea, but can the floor be cut on both sides of the tunnel, removed, cleaned, painted, and rewelded? Any other ideas? Thanks, Dennis |
| Dave_Darling |
Aug 26 2018, 12:05 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
I don't think there's any good way. You can drill the spot-welds and pull it out, which means pulling out the cross-member the same way. A lot of people settle for scraping up what they can access, and using a rust conversion product (phosphoric acid or related stuff) and then epoxy paint on it.
--DD |
DennisO Inside Tunnel Rust Aug 26 2018, 11:47 AM
DennisO Thanks Dave.
If the tunnel spot welds are removed... Aug 26 2018, 12:11 PM
IronHillRestorations Taking out the center tunnel is a major undertakin... Aug 26 2018, 03:30 PM
IronHillRestorations Here's the closest thing I could find to what ... Aug 26 2018, 03:46 PM
Mike Bellis Eastwood makes a good rust converter that I have u... Aug 26 2018, 05:26 PM
sithot Extend by Loctite is a great product I've used... Aug 26 2018, 05:33 PM
mgphoto I've seen where a section of the tunnel is cut... Aug 26 2018, 05:35 PM
DennisO Guys,
Thanks for all the great advice.
All the... Aug 26 2018, 06:33 PM
IronHillRestorations The Ospho won't hurt getting into seams. I wo... Aug 26 2018, 08:06 PM
bbrock
The Ospho won't hurt getting into seams. I w... Aug 26 2018, 09:28 PM
DennisO Perfect. I'll try it next weekend. thanks all.... Aug 26 2018, 09:36 PM
Curbandgutter While you are in the mood shoot some of that coati... Aug 27 2018, 01:15 PM
ClayPerrine Strip the tub to bare metal.
Clean up the rust on... Aug 27 2018, 03:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 12:21 PM |
