> my adventures in painting the car thread, DONE! Some final thoughts...
914 RZ-1
post Jul 11 2018, 09:55 PM
Porsche Padawan
So I painted my car. Got some orange peel, thought I'd see if anyone had ideas for getting rid of/minimizing it.
After painting:
After sanding with 1000 grit. The lighter areas are where I sanded, the darker areas are the lower points of the orange peel:
Option 1:
I'm thinking I need to go to 800 grit, then 1000, 1500, 2000, then polish. Before I do I thought I'd see if anyone else thinks this is a good idea based on what they may have done.
Option 2:
I can re-paint it. I'm thinking I will sand with 400 grit to rough up the surface and then re-spray.
Option 3:
I can polish it more, but the orange peel is still noticeable on the smaller pieces I've tried. I used a Torq X polisher, white pad, Chemical Guys V32 polish. I thought it might get smoother as I polished it with finer and finer pads/compounds, but I don't want to burn thru the paint. I put 3 coats of paint on.
914 RZ-1
post Aug 26 2018, 02:54 PM
Porsche Padawan
I have been told that compressed air can be very hot and that might be yet another issue I need to address. I'm going to run the compressor and some air tools for 20-30 minutes and see how hot the air gets.
I'm thinking I will place the first hose in a bucket of ice and see what that does. Air coolers are available but they are not cheap.
914 RZ-1   my adventures in painting the car thread   Jul 11 2018, 09:55 PM
porschetub   Oh dear,let it dry and start again,your paint is t...   Jul 11 2018, 11:30 PM
Front yard mechanic   Option 2 my vote   Jul 12 2018, 07:30 AM
Cairo94507   That's a bit of orange peel for sure. I would...   Jul 12 2018, 07:38 AM
burton73   You are going to need to go through the grits by s...   Jul 12 2018, 10:24 AM
Andyrew   Single stage? What paint are you using? Go 30% m...   Jul 12 2018, 11:05 AM
Andyrew   What temp reducer are you using? and how hot was i...   Jul 12 2018, 11:06 AM
mb911   I would wet sand again.. Then see what you have le...   Jul 12 2018, 11:08 AM
jmitro   definitely need to wet sand with finer and finer g...   Jul 12 2018, 11:33 AM
914 RZ-1   Thanks to all. I appreciate you input. I'm usi...   Jul 12 2018, 06:53 PM
Spoke   It was in the 80's when I painted. I probably...   Jul 16 2018, 11:08 AM
Olympic 914   many years ago I clipped the front end of my teene...   Jul 12 2018, 07:20 PM
914 RZ-1   Here is the result after wet-sanding with 800-1000...   Jul 13 2018, 12:32 PM
mb911   Here is the result after wet-sanding with 800-100...   Jul 13 2018, 03:20 PM
mepstein   Here is the result after wet-sanding with 800-10...   Jul 13 2018, 03:30 PM
ValcoOscar   Yeah Jeff...I kinda think you need more paint also...   Jul 13 2018, 03:31 PM
ConeDodger   Option 4: peel it and eat it. :rotfl:   Jul 13 2018, 06:45 PM
Andyrew   Hand sand only. No DA sanding for color sanding.   Jul 13 2018, 07:55 PM
914GT   Also, use a guide coat to show missed sanding scra...   Jul 13 2018, 08:46 PM
914 RZ-1   Here's the latest. I sanded with 400, cleaned ...   Jul 16 2018, 10:23 AM
Andyrew   Flash time starts from when the paint first leaves...   Jul 16 2018, 12:19 PM
914 RZ-1   I just to-read this and noticed that some people t...   Jul 16 2018, 02:44 PM
Dougster   As far as the paint mix, only do what the tech she...   Jul 16 2018, 04:00 PM
Andyrew   I think I spray at 20-25psi. With the nozzle a str...   Jul 16 2018, 04:00 PM
burton73   I think I spray at 20-25psi. With the nozzle a st...   Jul 16 2018, 08:21 PM
914 RZ-1   Here's the latest: Still a bit of orange peel...   Jul 16 2018, 10:11 PM
914 RZ-1   One other thing: how long are the face mask filter...   Jul 16 2018, 10:34 PM
Andyrew   Primer about 20 sessions. Not much VOC in the air....   Jul 16 2018, 11:02 PM
porschetub   Brave move going to that system for DIY newbie,cur...   Jul 17 2018, 12:58 AM
914 RZ-1   So my a-hole neighbor called the HOA, the city and...   Jul 25 2018, 06:33 PM
bbrock   That right there is why I live in the boonies, but...   Jul 25 2018, 06:53 PM
914 RZ-1   So, I'm still getting some orange peel. I thou...   Jul 31 2018, 04:17 PM
burton73   How long are you letting it sit before you color s...   Jul 31 2018, 04:29 PM
Andyrew   1. Yes. 2. Pinholes are typically from something...   Jul 31 2018, 04:30 PM
burton73   After you color sand, wipe it clean and look at it...   Jul 31 2018, 04:33 PM
ValcoOscar   Jeff- Keep in mind, our current HOT weather patte...   Jul 31 2018, 04:41 PM
Perry Kiehl   If you have a contaminant on the surface no amount...   Jul 31 2018, 05:09 PM
worn   If you have a contaminant on the surface no amoun...   Jul 31 2018, 05:23 PM
914 RZ-1   Thanks all. Here are my responses: I'm lettin...   Jul 31 2018, 05:14 PM
914GT   Don’t overlook the quality of your compressed ai...   Jul 31 2018, 05:39 PM
914 RZ-1   Don’t overlook the quality of your compressed a...   Jul 31 2018, 06:03 PM
Andyrew   [quote name='914GT' post='2634214' date='Jul 31 2...   Aug 1 2018, 11:09 AM
914 RZ-1   [quote name='914GT' post='2634214' date='Jul 31 ...   Aug 1 2018, 12:54 PM
mb911   Prepsol should be allowed to dry /evaporate before...   Jul 31 2018, 05:54 PM
914 RZ-1   Here's the latest: I painted both doors. I pu...   Aug 1 2018, 10:06 AM
Andyrew   What kind of gun with what size tip are you sprayi...   Aug 1 2018, 11:04 AM
914 RZ-1   What kind of gun with what size tip are you spray...   Aug 1 2018, 12:52 PM
Andyrew   What kind of gun with what size tip are you spra...   Aug 1 2018, 01:08 PM
914 RZ-1   [quote name='914 RZ-1' post='2634443' date='...   Aug 1 2018, 08:30 PM
Costa05   I thought I read in one of your posts that you wer...   Aug 1 2018, 12:22 PM
914 RZ-1   I thought I read in one of your posts that you we...   Aug 1 2018, 12:59 PM
Costa05   I thought I read in one of your posts that you w...   Aug 1 2018, 02:27 PM
aggiezig   Thats great. Check out the Eastwood videos on you...   Aug 1 2018, 02:28 PM
bbrock   Thats great. Check out the Eastwood videos on yo...   Aug 1 2018, 02:42 PM
aggiezig   You already have a ton of great feedback on this t...   Aug 1 2018, 02:25 PM
914 RZ-1   You already have a ton of great feedback on this ...   Aug 1 2018, 08:37 PM
914 RZ-1   +3 on Kevin Tetz. I learned most of this from his ...   Aug 1 2018, 08:41 PM
mepstein   +3 on Kevin Tetz. I learned most of this from his...   Aug 2 2018, 07:29 AM
Olympic 914   +3 on Kevin Tetz. I learned most of this from his...   Aug 2 2018, 09:00 AM
mbseto   Man this is a clinic. Almost makes me want to try...   Aug 1 2018, 10:06 PM
914 RZ-1   Man this is a clinic. Almost makes me want to tr...   Aug 2 2018, 06:23 PM
Perry Kiehl   FWIW, I have separate air hoses for only paint use...   Aug 2 2018, 07:18 AM
Rav914   Man this is a clinic. Almost makes me want to tr...   Aug 2 2018, 09:17 AM
914 RZ-1   I found it! Thanks! :beer2: https://www...   Aug 2 2018, 06:17 PM
aggiezig   I think that with enough trial/error & practic...   Aug 2 2018, 08:39 PM
914 RZ-1   Nice job! Yeah, it's taking me lots of pra...   Aug 8 2018, 12:18 PM
914dave   I had the same wrapped up in my paint. Tools incl...   Aug 4 2018, 07:34 AM
914 RZ-1   So I got the suggested filter: https://www.harborf...   Aug 8 2018, 12:15 PM
Andyrew   So I got the suggested filter: https://www.harbor...   Aug 8 2018, 12:42 PM
914 RZ-1   You need to put your regulator after the filter. Y...   Aug 8 2018, 05:57 PM
914GT   You are setting your pressure at the gun with the ...   Aug 8 2018, 07:05 PM
914 RZ-1   You are setting your pressure at the gun with the...   Aug 9 2018, 01:54 PM
Andyrew   Thinking back, I do remember having this issue onc...   Aug 9 2018, 02:01 PM
914 RZ-1   I've got similar orange peel on my hoods; were...   Aug 9 2018, 05:19 PM
Andyrew   Note. Spray the body side in one go, Not panel by ...   Aug 9 2018, 02:03 PM
914 RZ-1   Yeah, that's what I'm doing. I actually ha...   Aug 9 2018, 05:24 PM
Andyrew   Also noticed this review online. "We review...   Aug 9 2018, 02:05 PM
914 RZ-1   Wish I'd bothered to read the reviews. Maybe I...   Aug 9 2018, 05:21 PM
914 RZ-1   I'm STILL getting orange peel. To review, here...   Aug 19 2018, 05:46 PM
914 RZ-1   A picture after wet-sanding with 800 for your view...   Aug 19 2018, 05:54 PM
Andyrew   A picture after wet-sanding with 800 for your vie...   Aug 19 2018, 06:26 PM
914 RZ-1   A picture after wet-sanding with 800 for your vi...   Aug 19 2018, 06:32 PM
dakotaewing   Please show pictures of your compressor, hoses and...   Aug 19 2018, 06:01 PM
914 RZ-1   Please show pictures of your compressor, hoses an...   Aug 19 2018, 06:31 PM
Andyrew   Ya, I put 7 coats on mine when I did it. Took 3 fo...   Aug 19 2018, 06:55 PM
Andyrew   And I agree with temp. If your starting to spray a...   Aug 19 2018, 07:01 PM
dakotaewing   Upon initial review, it would appear that part of ...   Aug 19 2018, 07:54 PM
914 RZ-1   Upon initial review, it would appear that part of...   Aug 19 2018, 08:54 PM
Atech   [quote name='dakotaewing' post='2640512' date='Au...   Aug 20 2018, 01:40 AM
Atech   [i][quote name='dakotaewing' post='2640512' date...   Aug 20 2018, 01:52 AM
dakotaewing   The water trap on the wall will only catch a small...   Aug 19 2018, 09:35 PM
aggiezig   Lots of good tips about air and what not, but base...   Aug 20 2018, 08:22 AM
914 RZ-1   I have been told that compressed air can be very h...   Aug 26 2018, 02:54 PM
mb911   I have been told that compressed air can be very ...   Aug 26 2018, 03:17 PM
porschetub   [quote name='914 RZ-1' post='2642822' date='...   Aug 26 2018, 05:37 PM
ConeDodger   Get rid of that first length of hose of the compre...   Aug 26 2018, 04:03 PM
porschetub   Get rid of that first length of hose of the compr...   Aug 27 2018, 12:22 AM
IronHillRestorations   I'll 2nd Ben's opinion. I think you proba...   Aug 26 2018, 04:39 PM
IronHillRestorations   I've had more than one painter tell me that ea...   Aug 26 2018, 08:30 PM
gereed75   Lots of great info here. Don’t get overwhelmed. ...   Aug 27 2018, 07:26 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 08:36 PM
