2 Port Fuel Pump Conversion Revisited, Yea,...ANOTHER fuel pump thread! |
914bub |
Aug 26 2018, 11:39 AM
Member Group: Members Posts: 433 Joined: 16-August 13 From: Modesto CA. Member No.: 16,260 Region Association: None |
I know there are a lot of fuel pump conversion threads already, concerning both 2 port conversions and pump relocation. I'm about to wrap mine up soon. My car is a 72, 1.7 with stock fuel injection. I'm not trying to reinvent the wheel or over think this but I'm wondering why people use the fuel filter they do when converting?
I went with the standard recommended Napa,(square) filter and Bosch 2 port pump. The pump is selling on Amazon now for $56 prime. Hard to beat! I know the stock filter is the same design as the recommended filter when converting. Is that the reason people go with that filter? It doesn't make sense to me to step down the size on the line that runs through the tunnel only to step it back up at the filter. In other words, if the line running through the tunnel is 10mm and the fuel pump inlet is 10mm why not use a filter that has 10mm in and out? I had to go to 6, yes SIX different hardware and auto parts stores before the 6th had the fittings needed to make a simple 5/16-3/8 brass fitting. I looked on ebay and found motorcycle filters that are 10mm in and out. I know what your thinking, a motorcycle filter isn't going to cut it but the ones I found are 96mm long,(including nipples) so I've gotta believe it easily has as much filtration surface area as the square filter. My other concern was that the filter is probably for carburated bikes but since the filter is on the suction side of the pump would that matter? I know it needs to flow a lot of fuel but it's not on the high-pressure side of the pump. Here's my setup. Why can't the step fitting be eliminated and a different filter be used? Someone must have come up with a better set up I would think. |
914_teener |
Aug 26 2018, 12:08 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Almost exactly what I did.
Mounted in on the passenger side of the firewall so the filter could easily be accessed. Been great for 6 years like that. I used the ethanol resistant fuel line. |
914bub |
Aug 26 2018, 03:42 PM
Almost exactly what I did. Mounted in on the passenger side of the firewall so the filter could easily be accessed. Been great for 6 years like that. I used the ethanol resistant fuel line. Yea, I'm going to mount mine where you're talking about. I'll shoot pictures once it's installed. If you posted a picture of yours in the past your picture may have been one I referenced when I researched this. Any chance your car is Tangerine or green? |
Lo-Fi Version | Time is now: 8th June 2024 - 08:49 PM |
