> Inside Tunnel Rust
DennisO
post Aug 26 2018, 11:47 AM
Hi All,
I finally had time to get back to my '75 project after life kept getting in the way :-) I have about 95% of the car disassembled and have a pretty good idea of all the rust and hidden damage. The floor pans have some surface rust and a couple of spots that might need a patch (eg by brake/clutch pedals). However, the floor inside the tunnel has some pretty good rust that must be dealt with. Odd, but it look like water leaked just inside the tunnel and sat.
Is there a good way to remove the tunnel to access the floor underneath? This is probably not a good idea, but can the floor be cut on both sides of the tunnel, removed, cleaned, painted, and rewelded? Any other ideas?
Thanks,
Dennis
mgphoto
post Aug 26 2018, 05:35 PM
"If there is a mistake it will find me"
I've seen where a section of the tunnel is cut and folded back for access so wire brush can be used for clean up.
After cleaning, treating and epoxy primer the section is bent back into position and welded.
- Lo-Fi Version Time is now: 2nd April 2026 - 12:20 PM
