| DennisO |
Aug 26 2018, 11:47 AM
Member ![]() ![]() Group: Members Posts: 61 Joined: 9-June 17 From: Clayton, NC Member No.: 21,162 Region Association: South East States
Hi All,
I finally had time to get back to my '75 project after life kept getting in the way :-) I have about 95% of the car disassembled and have a pretty good idea of all the rust and hidden damage. The floor pans have some surface rust and a couple of spots that might need a patch (eg by brake/clutch pedals). However, the floor inside the tunnel has some pretty good rust that must be dealt with. Odd, but it look like water leaked just inside the tunnel and sat. Is there a good way to remove the tunnel to access the floor underneath? This is probably not a good idea, but can the floor be cut on both sides of the tunnel, removed, cleaned, painted, and rewelded? Any other ideas? Thanks, Dennis |
| IronHillRestorations |
Aug 26 2018, 08:06 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,927 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
The Ospho won't hurt getting into seams. I wouldn't use a torch, maybe a blow dryer or heat gun.
| bbrock |
Aug 26 2018, 09:28 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,269 Joined: 17-February 17 From: Montana Member No.: 20,845 Region Association: Rocky Mountains
The Ospho won't hurt getting into seams. I wouldn't use a torch, maybe a blow dryer or heat gun. (IMG:style_emoticons/default/agree.gif) Getting Ospho in the seams should actually be a good thing as long as the water rinse also gets in there to neutralize it. It will convert any rust it contacts in the seams and leave a protective phophorous coating behind. |
DennisO Inside Tunnel Rust Aug 26 2018, 11:47 AM
Dave_Darling I don't think there's any good way. You c... Aug 26 2018, 12:05 PM
DennisO Thanks Dave.
If the tunnel spot welds are removed... Aug 26 2018, 12:11 PM
IronHillRestorations Taking out the center tunnel is a major undertakin... Aug 26 2018, 03:30 PM
IronHillRestorations Here's the closest thing I could find to what ... Aug 26 2018, 03:46 PM
Mike Bellis Eastwood makes a good rust converter that I have u... Aug 26 2018, 05:26 PM
sithot Extend by Loctite is a great product I've used... Aug 26 2018, 05:33 PM
mgphoto I've seen where a section of the tunnel is cut... Aug 26 2018, 05:35 PM
DennisO Guys,
Thanks for all the great advice.
All the... Aug 26 2018, 06:33 PM
DennisO Perfect. I'll try it next weekend. thanks all.... Aug 26 2018, 09:36 PM
Curbandgutter While you are in the mood shoot some of that coati... Aug 27 2018, 01:15 PM
ClayPerrine Strip the tub to bare metal.
Clean up the rust on... Aug 27 2018, 03:18 PM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:06 PM |
