Downerman |
Member ![]() ![]() Group: Members Posts: 168 Joined: 23-April 09 From: Monterey County, California Member No.: 10,296 Region Association: None ![]() |
1973 2.0 with dual bleaders, drivers side is leaking a very small amount off the spring/ebrake lever. I have wiped all surfaces and checked the top feeder and they all appear to be dry. I don't know these rear units very well but is there a seal in those ebrake/levers area?
Restoring the car so all calipers were re-built with standard kits. New brake lines, the works. Dave |
Mblizzard |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,033 Joined: 28-January 13 From: Knoxville Tn Member No.: 15,438 Region Association: South East States ![]() |
You may be better at rebuilding brakes than I am. But after failing once on a rebuild and getting a crashed car, it is hard to justify doing it yourself. I know my brakes are far better after adding PMB calipers. There are many here that will tell stories of just what a great job PMB does. Cheap? No but hard to justify saving some money when you are placing your car and life on the line.
Lo-Fi Version | Time is now: 16th June 2024 - 11:09 AM |
