intermittent starter not turning issue |
rosenfe |
Aug 27 2018, 10:33 AM
Senior Member Group: Members Posts: 561 Joined: 14-October 13 From: northern california Member No.: 16,512 Region Association: None |
On my 74 2.0,when turning key ,power turns on,red and green lights come on,but starter will not turn.Jumping starter directly engages starter and it will continue to engage starter for a day or so and then no engagement.Car is in good shape,wires to starter look good and are tight.
Any suggestions.would this be a good candidate for mark henry relay?.Battery is good,starter works well. |
Mark Henry |
Aug 27 2018, 11:01 AM
The stock bosch solenoid needs a full 9v to kick in, likely due to old wiring, corrosion, resistance you're not getting a full 9v.
Likely my fix will solve the issue, but you should still clean all your grounds, terminals, connections, etc. Link at the bottom of my signature. |
Lo-Fi Version | Time is now: 8th June 2024 - 04:54 PM |
