Measurements for 911 Flag Mirrors, outside measurements with mirrors on |
jim912928 |
Dec 3 2004, 11:36 AM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Well, I finally got around to taking some measurements. I did not take the mirrors off, but rather took measurements from 3 points on each door to the base of the rubber gasket. On this first picture...the key to the alignment is the yellow line...that line when looking at the car from the front should be vertical on both sides!
Also, for strength, you must use the 911 backing plate. I riveted mine on after having the holes cut in. Drivers side: Attached image(s) |
jim_hoyland |
Aug 29 2018, 10:14 AM
Get that VIN ? Group: Members Posts: 9,319 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
In searching for an exact replacement for the passenger side door, I got this pic and explanation. I'm not certain the angle is correct, but I'm going to wait for the original number shown above by Steve and I
Vendor: "this is an original one from back in the 80s before it was superseded to that part number you're asking about but this was used on 77 930 and 911 all the way up until the later 80s. For sure it's a right-hand US mirror base" Attached thumbnail(s) |
Lo-Fi Version | Time is now: 9th June 2024 - 02:36 PM |
