| HerdofCrickets |
Sep 3 2018, 07:51 PM
Member ![]() ![]() Group: Members Posts: 68 Joined: 23-September 16 From: Overland Park, KS Member No.: 20,423 Region Association: None |
So perhaps I'm slightly not overly excited about smashing my hands up there to do the adjustment (ie lazy) but.... I'm about to try my first valve adjustment, is there a reason we don't drop the exhaust out of the way? Seems it'd be MUCH easier without that blocking all the workspace!
| worn |
Sep 3 2018, 08:14 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,560 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
So perhaps I'm slightly not overly excited about smashing my hands up there to do the adjustment (ie lazy) but.... I'm about to try my first valve adjustment, is there a reason we don't drop the exhaust out of the way? Seems it'd be MUCH easier without that blocking all the workspace! It can be dirty and uncomfortable, and dirty. I think it can also produce some wear and tear on the heads. Often the studs come out of the heads, and grind their rusty way back into place. This puts wear on the threads in the aluminum. Although the copper gaskets are softer than aluminum they aren’t a great deal softer. So there is mashing required to get a seal. The fasteners rust no matter what, so they can break off. That is what I was thinking anyway. |
HerdofCrickets Valve Adjustment Question Sep 3 2018, 07:51 PM
Dave_Darling Just to note that there is a difference between ... Sep 3 2018, 08:50 PM
HerdofCrickets
Just to note that there is a difference between ... Sep 3 2018, 09:44 PM
cary I think we should call it valve clearance inspecti... Sep 3 2018, 09:46 PM
TheCabinetmaker Removing the exhaust to adjust valves is kinda lik... Sep 4 2018, 06:07 AM
falcor75 I'd rather pull the motor and gearbox than pul... Sep 4 2018, 06:11 AM
HerdofCrickets Good deal. I was looking for an easy way out but ... Sep 4 2018, 08:01 AM
cuddy_k If there's anything else you're thinking a... Sep 4 2018, 08:29 AM
HerdofCrickets
If there's anything else you're thinking ... Sep 4 2018, 08:54 AM
Bartlett 914
If there's anything else you're thinking... Sep 4 2018, 09:37 AM
HerdofCrickets
valves make tapping sounds. if there is a knocki... Sep 4 2018, 09:46 AM
TheCabinetmaker Not a valve adjustment problem. Dropped valve seat... Sep 4 2018, 09:55 AM
billh1963
Not a valve adjustment problem. Dropped valve sea... Sep 4 2018, 10:26 AM
cuddy_k :agree: but I hope we're wrong. Sep 4 2018, 10:49 AM
HerdofCrickets
Well me to... Sep 4 2018, 12:02 PM
brant
Well me t... Sep 4 2018, 01:01 PM
billh1963
Adjust your valves
then if the noise still exist... Sep 4 2018, 01:33 PM
Dave_Darling
Hopefully you are not dropping a valve seat
most ... Sep 4 2018, 04:36 PM
HerdofCrickets Finally got the stupid cover off.
My feeler gauge... Sep 4 2018, 08:09 PM
TheCabinetmaker How about the other side? Sep 4 2018, 11:26 PM
Porschef :agree:
Yes, there are 4 more on the other side.... Sep 5 2018, 04:03 AM
HerdofCrickets
:agree:
Yes, there are 4 more on the other side... Sep 5 2018, 07:22 AM
brant did You find each cylinder’s tdc?
Sorry dumb qu... Sep 5 2018, 07:17 AM
falcor75 Yup, Passenger side is for cylinder 3 and 4, drive... Sep 5 2018, 07:36 AM
bdstone914 Couple of tips. To unclip the bale runs a shop to... Sep 5 2018, 08:02 AM
HerdofCrickets
Couple of tips. To unclip the bale runs a shop t... Sep 5 2018, 08:10 AM
TheCabinetmaker And that is why I won't remove heat exchangers... Sep 5 2018, 08:10 AM
cary Here's some good reading.
https://www.pelicanp... Sep 5 2018, 08:28 AM
brant You have to put them at TDC to see whether you hav... Sep 5 2018, 09:09 AM
HerdofCrickets Drivers side.... I struggled for about 30 minutes ... Sep 5 2018, 08:36 PM
TheCabinetmaker Time for your first engine drop. Sep 5 2018, 09:18 PM
HerdofCrickets Seems like it! Getting the engine out doesn... Sep 6 2018, 07:18 AM
DRPHIL914
Seems like it! Getting the engine out doesn... Sep 6 2018, 07:29 AM
HerdofCrickets
[quote name='HerdofCrickets' post='2646011' date=... Sep 6 2018, 08:15 AM
TheCabinetmaker I diagnose Dirk Wright's desease! Prognosi... Sep 6 2018, 10:05 AM
cuddy_k Glad you found the video helpful.
As long as you... Sep 6 2018, 10:13 AM
VaccaRabite If you are waffling on Chris's engine cradle, ... Sep 6 2018, 11:53 AM
HerdofCrickets Not waffling at all, it's on my shortlist of t... Sep 6 2018, 12:04 PM
RoadGlue Just a quick note that Chris's cradle doesn... Sep 6 2018, 12:46 PM
HerdofCrickets As you can tell, the whole "mechanic" th... Sep 7 2018, 07:40 AM
TheCabinetmaker What are you gonna do with a hoist? Sep 7 2018, 08:47 AM
HerdofCrickets Once I drop the engine onto the jack & plate, ... Sep 7 2018, 08:59 AM
brant Or working with n the floor is perfectly acceptabl... Sep 7 2018, 09:36 AM
TheCabinetmaker After you remove the trans, get a couple of friend... Sep 7 2018, 09:38 AM
cuddy_k Engine stand:
https://www.harborfreight.com/1000-... Sep 7 2018, 11:25 AM
HerdofCrickets
Engine stand:
https://www.harborfreight.com/1000... Sep 7 2018, 11:55 AM
TheCabinetmaker So, I nailed it on post#13? Imagine that! Sep 17 2018, 10:16 AM
HerdofCrickets
S... Sep 17 2018, 10:26 AM
TheCabinetmaker Get a Haynes manual or the Tom Wilson engine rebui... Sep 17 2018, 10:34 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:31 AM |
