| HerdofCrickets |
Sep 3 2018, 07:51 PM
Member ![]() ![]() Group: Members Posts: 68 Joined: 23-September 16 From: Overland Park, KS Member No.: 20,423 Region Association: None |
So perhaps I'm slightly not overly excited about smashing my hands up there to do the adjustment (ie lazy) but.... I'm about to try my first valve adjustment, is there a reason we don't drop the exhaust out of the way? Seems it'd be MUCH easier without that blocking all the workspace!
| iankarr |
Sep 4 2018, 10:49 AM
The wrencher formerly known as Cuddy_K ![]() ![]() ![]() ![]() Group: Members Posts: 2,595 Joined: 22-May 15 From: Heber City, UT Member No.: 18,749 Region Association: Intermountain Region
(IMG:style_emoticons/default/agree.gif) but I hope we're wrong.
| HerdofCrickets |
Sep 4 2018, 12:02 PM
Well me too, I can't find a darn thing online about how to fix that so... that makes me nervous! (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/slap.gif) |
| brant |
Sep 4 2018, 01:01 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,167 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Well me too, I can't find a darn thing online about how to fix that so... that makes me nervous! (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/slap.gif) Hopefully you are not dropping a valve seat most likely there would be a significant compression loss in that cylinder that you would be able to detect through a leak down test. but fixing a valve seat would require dropping the motor, pulling the head and having a specialist that is familiar with aluminum heads on air cooled cars make you and install another valve seat. this would need to be done before the entire seat dropped into the combustion chamber and blew up the rest of the motor (possible, bend rod, hole in block, holed piston, contaminated oil passages, etc) most people that actually have a dropping valve seat would consider pulling the head from the other bank and consider having those seats checked at the same time whom ever last touched the head, could possibly not have the experience required to rebuild the head and seats correctly.... causing one to come loose and putting the other 7 seats at risk for a similar fate. if they were rebuilt by a known and skilled specialist... you would be more likely to be safe that only one seat is loose and the other 7 are not at risk. many people will go ahead and fully rebuild the motor at this point... especially if its a tired motor. Sitting for a decade is not good on a motor. but possibly further inspection will show your rings, valve springs and other items are fine and not in need of replacement or rebuild.... and possibly you will need to replace some of those items after 10 years. an expert with experience, or a a lot of research and careful measuring can help make that decision. Adjust your valves then if the noise still exists... don't drive it without digging deeper |
| Dave_Darling |
Sep 4 2018, 04:36 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Hopefully you are not dropping a valve seat most likely there would be a significant compression loss in that cylinder that you would be able to detect through a leak down test. You would be able to detect it by listening to the starter. If there is a pattern to the sound that drops out every fourth time, there's a good chance you have one "dead hole". The sound would be something like "RR-RR-RR-..-RR-RR-RR-..". That was how I found the last dropped seat on my car.... --DD |
HerdofCrickets Valve Adjustment Question Sep 3 2018, 07:51 PM
worn
So perhaps I'm slightly not overly excited ab... Sep 3 2018, 08:14 PM
Dave_Darling Just to note that there is a difference between ... Sep 3 2018, 08:50 PM
HerdofCrickets
Just to note that there is a difference between ... Sep 3 2018, 09:44 PM
cary I think we should call it valve clearance inspecti... Sep 3 2018, 09:46 PM
TheCabinetmaker Removing the exhaust to adjust valves is kinda lik... Sep 4 2018, 06:07 AM
falcor75 I'd rather pull the motor and gearbox than pul... Sep 4 2018, 06:11 AM
HerdofCrickets Good deal. I was looking for an easy way out but ... Sep 4 2018, 08:01 AM
cuddy_k If there's anything else you're thinking a... Sep 4 2018, 08:29 AM
HerdofCrickets
If there's anything else you're thinking ... Sep 4 2018, 08:54 AM
Bartlett 914
If there's anything else you're thinking... Sep 4 2018, 09:37 AM
HerdofCrickets
valves make tapping sounds. if there is a knocki... Sep 4 2018, 09:46 AM
TheCabinetmaker Not a valve adjustment problem. Dropped valve seat... Sep 4 2018, 09:55 AM
billh1963
Not a valve adjustment problem. Dropped valve sea... Sep 4 2018, 10:26 AM
billh1963
Adjust your valves
then if the noise still exist... Sep 4 2018, 01:33 PM
HerdofCrickets Finally got the stupid cover off.
My feeler gauge... Sep 4 2018, 08:09 PM
TheCabinetmaker How about the other side? Sep 4 2018, 11:26 PM
Porschef :agree:
Yes, there are 4 more on the other side.... Sep 5 2018, 04:03 AM
HerdofCrickets
:agree:
Yes, there are 4 more on the other side... Sep 5 2018, 07:22 AM
brant did You find each cylinder’s tdc?
Sorry dumb qu... Sep 5 2018, 07:17 AM
falcor75 Yup, Passenger side is for cylinder 3 and 4, drive... Sep 5 2018, 07:36 AM
bdstone914 Couple of tips. To unclip the bale runs a shop to... Sep 5 2018, 08:02 AM
HerdofCrickets
Couple of tips. To unclip the bale runs a shop t... Sep 5 2018, 08:10 AM
TheCabinetmaker And that is why I won't remove heat exchangers... Sep 5 2018, 08:10 AM
cary Here's some good reading.
https://www.pelicanp... Sep 5 2018, 08:28 AM
brant You have to put them at TDC to see whether you hav... Sep 5 2018, 09:09 AM
HerdofCrickets Drivers side.... I struggled for about 30 minutes ... Sep 5 2018, 08:36 PM
TheCabinetmaker Time for your first engine drop. Sep 5 2018, 09:18 PM
HerdofCrickets Seems like it! Getting the engine out doesn... Sep 6 2018, 07:18 AM
DRPHIL914
Seems like it! Getting the engine out doesn... Sep 6 2018, 07:29 AM
HerdofCrickets
[quote name='HerdofCrickets' post='2646011' date=... Sep 6 2018, 08:15 AM
TheCabinetmaker I diagnose Dirk Wright's desease! Prognosi... Sep 6 2018, 10:05 AM
cuddy_k Glad you found the video helpful.
As long as you... Sep 6 2018, 10:13 AM
VaccaRabite If you are waffling on Chris's engine cradle, ... Sep 6 2018, 11:53 AM
HerdofCrickets Not waffling at all, it's on my shortlist of t... Sep 6 2018, 12:04 PM
RoadGlue Just a quick note that Chris's cradle doesn... Sep 6 2018, 12:46 PM
HerdofCrickets As you can tell, the whole "mechanic" th... Sep 7 2018, 07:40 AM
TheCabinetmaker What are you gonna do with a hoist? Sep 7 2018, 08:47 AM
HerdofCrickets Once I drop the engine onto the jack & plate, ... Sep 7 2018, 08:59 AM
brant Or working with n the floor is perfectly acceptabl... Sep 7 2018, 09:36 AM
TheCabinetmaker After you remove the trans, get a couple of friend... Sep 7 2018, 09:38 AM
cuddy_k Engine stand:
https://www.harborfreight.com/1000-... Sep 7 2018, 11:25 AM
HerdofCrickets
Engine stand:
https://www.harborfreight.com/1000... Sep 7 2018, 11:55 AM
TheCabinetmaker So, I nailed it on post#13? Imagine that! Sep 17 2018, 10:16 AM
HerdofCrickets
S... Sep 17 2018, 10:26 AM
TheCabinetmaker Get a Haynes manual or the Tom Wilson engine rebui... Sep 17 2018, 10:34 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 11:34 AM |
