| HerdofCrickets |
Sep 3 2018, 07:51 PM
Member ![]() ![]() Group: Members Posts: 68 Joined: 23-September 16 From: Overland Park, KS Member No.: 20,423 Region Association: None |
So perhaps I'm slightly not overly excited about smashing my hands up there to do the adjustment (ie lazy) but.... I'm about to try my first valve adjustment, is there a reason we don't drop the exhaust out of the way? Seems it'd be MUCH easier without that blocking all the workspace!
| bdstone914 |
Sep 5 2018, 08:02 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,280 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Couple of tips. To unclip the bale runs a shop towel through the loop in the center and pull hard from below. Put each cyl at TDC and check the rocker position. If a seat is dropped ( inwards ) the rocker will have a lot of slop. I correctly adjusted valve will move just enough to make a click when moved by hand. Valves stretch and get longer. I would do a compression check. That will tell you a lot. Low number could be dropped seat, out of adjustment valve. Exhausts grow more due to the heat on them. If you have number below 100 psi of greater than 20 psi range after adjustment it is time for a valve job.
You may consider not completely dropping the motor but unbolting the trans mounts, engine mounts, cables and drop it down a few inches for better access. Leave the CV's attached. Still a lot of work. I would not remove the exhaust as you may break a stud. |
HerdofCrickets Valve Adjustment Question Sep 3 2018, 07:51 PM
worn
So perhaps I'm slightly not overly excited ab... Sep 3 2018, 08:14 PM
Dave_Darling Just to note that there is a difference between ... Sep 3 2018, 08:50 PM
HerdofCrickets
Just to note that there is a difference between ... Sep 3 2018, 09:44 PM
cary I think we should call it valve clearance inspecti... Sep 3 2018, 09:46 PM
TheCabinetmaker Removing the exhaust to adjust valves is kinda lik... Sep 4 2018, 06:07 AM
falcor75 I'd rather pull the motor and gearbox than pul... Sep 4 2018, 06:11 AM
HerdofCrickets Good deal. I was looking for an easy way out but ... Sep 4 2018, 08:01 AM
cuddy_k If there's anything else you're thinking a... Sep 4 2018, 08:29 AM
HerdofCrickets
If there's anything else you're thinking ... Sep 4 2018, 08:54 AM
Bartlett 914
If there's anything else you're thinking... Sep 4 2018, 09:37 AM
HerdofCrickets
valves make tapping sounds. if there is a knocki... Sep 4 2018, 09:46 AM
TheCabinetmaker Not a valve adjustment problem. Dropped valve seat... Sep 4 2018, 09:55 AM
billh1963
Not a valve adjustment problem. Dropped valve sea... Sep 4 2018, 10:26 AM
cuddy_k :agree: but I hope we're wrong. Sep 4 2018, 10:49 AM
HerdofCrickets
Well me to... Sep 4 2018, 12:02 PM
brant
Well me t... Sep 4 2018, 01:01 PM
billh1963
Adjust your valves
then if the noise still exist... Sep 4 2018, 01:33 PM
Dave_Darling
Hopefully you are not dropping a valve seat
most ... Sep 4 2018, 04:36 PM
HerdofCrickets Finally got the stupid cover off.
My feeler gauge... Sep 4 2018, 08:09 PM
TheCabinetmaker How about the other side? Sep 4 2018, 11:26 PM
Porschef :agree:
Yes, there are 4 more on the other side.... Sep 5 2018, 04:03 AM
HerdofCrickets
:agree:
Yes, there are 4 more on the other side... Sep 5 2018, 07:22 AM
brant did You find each cylinder’s tdc?
Sorry dumb qu... Sep 5 2018, 07:17 AM
falcor75 Yup, Passenger side is for cylinder 3 and 4, drive... Sep 5 2018, 07:36 AM
HerdofCrickets
Couple of tips. To unclip the bale runs a shop t... Sep 5 2018, 08:10 AM
TheCabinetmaker And that is why I won't remove heat exchangers... Sep 5 2018, 08:10 AM
cary Here's some good reading.
https://www.pelicanp... Sep 5 2018, 08:28 AM
brant You have to put them at TDC to see whether you hav... Sep 5 2018, 09:09 AM
HerdofCrickets Drivers side.... I struggled for about 30 minutes ... Sep 5 2018, 08:36 PM
TheCabinetmaker Time for your first engine drop. Sep 5 2018, 09:18 PM
HerdofCrickets Seems like it! Getting the engine out doesn... Sep 6 2018, 07:18 AM
DRPHIL914
Seems like it! Getting the engine out doesn... Sep 6 2018, 07:29 AM
HerdofCrickets
[quote name='HerdofCrickets' post='2646011' date=... Sep 6 2018, 08:15 AM
TheCabinetmaker I diagnose Dirk Wright's desease! Prognosi... Sep 6 2018, 10:05 AM
cuddy_k Glad you found the video helpful.
As long as you... Sep 6 2018, 10:13 AM
VaccaRabite If you are waffling on Chris's engine cradle, ... Sep 6 2018, 11:53 AM
HerdofCrickets Not waffling at all, it's on my shortlist of t... Sep 6 2018, 12:04 PM
RoadGlue Just a quick note that Chris's cradle doesn... Sep 6 2018, 12:46 PM
HerdofCrickets As you can tell, the whole "mechanic" th... Sep 7 2018, 07:40 AM
TheCabinetmaker What are you gonna do with a hoist? Sep 7 2018, 08:47 AM
HerdofCrickets Once I drop the engine onto the jack & plate, ... Sep 7 2018, 08:59 AM
brant Or working with n the floor is perfectly acceptabl... Sep 7 2018, 09:36 AM
TheCabinetmaker After you remove the trans, get a couple of friend... Sep 7 2018, 09:38 AM
cuddy_k Engine stand:
https://www.harborfreight.com/1000-... Sep 7 2018, 11:25 AM
HerdofCrickets
Engine stand:
https://www.harborfreight.com/1000... Sep 7 2018, 11:55 AM
TheCabinetmaker So, I nailed it on post#13? Imagine that! Sep 17 2018, 10:16 AM
HerdofCrickets
S... Sep 17 2018, 10:26 AM
TheCabinetmaker Get a Haynes manual or the Tom Wilson engine rebui... Sep 17 2018, 10:34 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:31 AM |
