| HerdofCrickets |
Sep 3 2018, 07:51 PM
Member ![]() ![]() Group: Members Posts: 68 Joined: 23-September 16 From: Overland Park, KS Member No.: 20,423 Region Association: None |
So perhaps I'm slightly not overly excited about smashing my hands up there to do the adjustment (ie lazy) but.... I'm about to try my first valve adjustment, is there a reason we don't drop the exhaust out of the way? Seems it'd be MUCH easier without that blocking all the workspace!
| cary |
Sep 5 2018, 08:28 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,900 Joined: 26-January 04 From: Sherwood Oregon Member No.: 1,608 Region Association: Pacific Northwest
Here's some good reading.
https://www.pelicanparts.com/techarticles/9...alve_adjust.htm I cheat. I have a bracket (Super In Law creation) that holds one wheel in place and I do it on a 2 post lift. The hardest part is marking the flywheel. |
HerdofCrickets Valve Adjustment Question Sep 3 2018, 07:51 PM
worn
So perhaps I'm slightly not overly excited ab... Sep 3 2018, 08:14 PM
Dave_Darling Just to note that there is a difference between ... Sep 3 2018, 08:50 PM
HerdofCrickets
Just to note that there is a difference between ... Sep 3 2018, 09:44 PM
cary I think we should call it valve clearance inspecti... Sep 3 2018, 09:46 PM
TheCabinetmaker Removing the exhaust to adjust valves is kinda lik... Sep 4 2018, 06:07 AM
falcor75 I'd rather pull the motor and gearbox than pul... Sep 4 2018, 06:11 AM
HerdofCrickets Good deal. I was looking for an easy way out but ... Sep 4 2018, 08:01 AM
cuddy_k If there's anything else you're thinking a... Sep 4 2018, 08:29 AM
HerdofCrickets
If there's anything else you're thinking ... Sep 4 2018, 08:54 AM
Bartlett 914
If there's anything else you're thinking... Sep 4 2018, 09:37 AM
HerdofCrickets
valves make tapping sounds. if there is a knocki... Sep 4 2018, 09:46 AM
TheCabinetmaker Not a valve adjustment problem. Dropped valve seat... Sep 4 2018, 09:55 AM
billh1963
Not a valve adjustment problem. Dropped valve sea... Sep 4 2018, 10:26 AM
cuddy_k :agree: but I hope we're wrong. Sep 4 2018, 10:49 AM
HerdofCrickets
Well me to... Sep 4 2018, 12:02 PM
brant
Well me t... Sep 4 2018, 01:01 PM
billh1963
Adjust your valves
then if the noise still exist... Sep 4 2018, 01:33 PM
Dave_Darling
Hopefully you are not dropping a valve seat
most ... Sep 4 2018, 04:36 PM
HerdofCrickets Finally got the stupid cover off.
My feeler gauge... Sep 4 2018, 08:09 PM
TheCabinetmaker How about the other side? Sep 4 2018, 11:26 PM
Porschef :agree:
Yes, there are 4 more on the other side.... Sep 5 2018, 04:03 AM
HerdofCrickets
:agree:
Yes, there are 4 more on the other side... Sep 5 2018, 07:22 AM
brant did You find each cylinder’s tdc?
Sorry dumb qu... Sep 5 2018, 07:17 AM
falcor75 Yup, Passenger side is for cylinder 3 and 4, drive... Sep 5 2018, 07:36 AM
bdstone914 Couple of tips. To unclip the bale runs a shop to... Sep 5 2018, 08:02 AM
HerdofCrickets
Couple of tips. To unclip the bale runs a shop t... Sep 5 2018, 08:10 AM
TheCabinetmaker And that is why I won't remove heat exchangers... Sep 5 2018, 08:10 AM
brant You have to put them at TDC to see whether you hav... Sep 5 2018, 09:09 AM
HerdofCrickets Drivers side.... I struggled for about 30 minutes ... Sep 5 2018, 08:36 PM
TheCabinetmaker Time for your first engine drop. Sep 5 2018, 09:18 PM
HerdofCrickets Seems like it! Getting the engine out doesn... Sep 6 2018, 07:18 AM
DRPHIL914
Seems like it! Getting the engine out doesn... Sep 6 2018, 07:29 AM
HerdofCrickets
[quote name='HerdofCrickets' post='2646011' date=... Sep 6 2018, 08:15 AM
TheCabinetmaker I diagnose Dirk Wright's desease! Prognosi... Sep 6 2018, 10:05 AM
cuddy_k Glad you found the video helpful.
As long as you... Sep 6 2018, 10:13 AM
VaccaRabite If you are waffling on Chris's engine cradle, ... Sep 6 2018, 11:53 AM
HerdofCrickets Not waffling at all, it's on my shortlist of t... Sep 6 2018, 12:04 PM
RoadGlue Just a quick note that Chris's cradle doesn... Sep 6 2018, 12:46 PM
HerdofCrickets As you can tell, the whole "mechanic" th... Sep 7 2018, 07:40 AM
TheCabinetmaker What are you gonna do with a hoist? Sep 7 2018, 08:47 AM
HerdofCrickets Once I drop the engine onto the jack & plate, ... Sep 7 2018, 08:59 AM
brant Or working with n the floor is perfectly acceptabl... Sep 7 2018, 09:36 AM
TheCabinetmaker After you remove the trans, get a couple of friend... Sep 7 2018, 09:38 AM
cuddy_k Engine stand:
https://www.harborfreight.com/1000-... Sep 7 2018, 11:25 AM
HerdofCrickets
Engine stand:
https://www.harborfreight.com/1000... Sep 7 2018, 11:55 AM
TheCabinetmaker So, I nailed it on post#13? Imagine that! Sep 17 2018, 10:16 AM
HerdofCrickets
S... Sep 17 2018, 10:26 AM
TheCabinetmaker Get a Haynes manual or the Tom Wilson engine rebui... Sep 17 2018, 10:34 AM![]() ![]() |
Lo-Fi Version | Time is now: 2nd April 2026 - 08:31 AM |
