> Valve Adjustment Question, Valve Adjustment Question
HerdofCrickets
post Sep 3 2018, 07:51 PM
So perhaps I'm slightly not overly excited about smashing my hands up there to do the adjustment (ie lazy) but.... I'm about to try my first valve adjustment, is there a reason we don't drop the exhaust out of the way? Seems it'd be MUCH easier without that blocking all the workspace!
brant
post Sep 5 2018, 09:09 AM
You have to put them at TDC to see whether you have a problem or not
dropping the cover and looking will not tell you
you must rotate the motor. Put each cylinder at TDC. and with no experience to help you judge what the correct amount of free play should be..... you must buy another feeler gauge and check each valve while you have that cylinder at TDC
(there is the captain crusty technique... but I think it would only confuse you at this point. get a Haynes manual. put each cylinder at TDC.... or take it to a mechanic... but this is something you can easily do yourself)
HerdofCrickets   Valve Adjustment Question   Sep 3 2018, 07:51 PM
worn   So perhaps I'm slightly not overly excited ab...   Sep 3 2018, 08:14 PM
Dave_Darling   Just to note that there is a difference between ...   Sep 3 2018, 08:50 PM
HerdofCrickets   Just to note that there is a difference between ...   Sep 3 2018, 09:44 PM
cary   I think we should call it valve clearance inspecti...   Sep 3 2018, 09:46 PM
TheCabinetmaker   Removing the exhaust to adjust valves is kinda lik...   Sep 4 2018, 06:07 AM
falcor75   I'd rather pull the motor and gearbox than pul...   Sep 4 2018, 06:11 AM
HerdofCrickets   Good deal. I was looking for an easy way out but ...   Sep 4 2018, 08:01 AM
cuddy_k   If there's anything else you're thinking a...   Sep 4 2018, 08:29 AM
HerdofCrickets   If there's anything else you're thinking ...   Sep 4 2018, 08:54 AM
Bartlett 914   If there's anything else you're thinking...   Sep 4 2018, 09:37 AM
HerdofCrickets   valves make tapping sounds. if there is a knocki...   Sep 4 2018, 09:46 AM
TheCabinetmaker   Not a valve adjustment problem. Dropped valve seat...   Sep 4 2018, 09:55 AM
billh1963   Not a valve adjustment problem. Dropped valve sea...   Sep 4 2018, 10:26 AM
cuddy_k   :agree: but I hope we're wrong.   Sep 4 2018, 10:49 AM
HerdofCrickets   :agree: but I hope we're wrong. Well me to...   Sep 4 2018, 12:02 PM
brant   :agree: but I hope we're wrong. Well me t...   Sep 4 2018, 01:01 PM
billh1963   Adjust your valves then if the noise still exist...   Sep 4 2018, 01:33 PM
Dave_Darling   Hopefully you are not dropping a valve seat most ...   Sep 4 2018, 04:36 PM
HerdofCrickets   Finally got the stupid cover off. My feeler gauge...   Sep 4 2018, 08:09 PM
TheCabinetmaker   How about the other side?   Sep 4 2018, 11:26 PM
Porschef   :agree: Yes, there are 4 more on the other side....   Sep 5 2018, 04:03 AM
HerdofCrickets   :agree: Yes, there are 4 more on the other side...   Sep 5 2018, 07:22 AM
brant   did You find each cylinder’s tdc? Sorry dumb qu...   Sep 5 2018, 07:17 AM
falcor75   Yup, Passenger side is for cylinder 3 and 4, drive...   Sep 5 2018, 07:36 AM
bdstone914   Couple of tips. To unclip the bale runs a shop to...   Sep 5 2018, 08:02 AM
HerdofCrickets   Couple of tips. To unclip the bale runs a shop t...   Sep 5 2018, 08:10 AM
TheCabinetmaker   And that is why I won't remove heat exchangers...   Sep 5 2018, 08:10 AM
cary   Here's some good reading. https://www.pelicanp...   Sep 5 2018, 08:28 AM
brant   You have to put them at TDC to see whether you hav...   Sep 5 2018, 09:09 AM
HerdofCrickets   Drivers side.... I struggled for about 30 minutes ...   Sep 5 2018, 08:36 PM
TheCabinetmaker   Time for your first engine drop.   Sep 5 2018, 09:18 PM
HerdofCrickets   Seems like it! Getting the engine out doesn...   Sep 6 2018, 07:18 AM
DRPHIL914   Seems like it! Getting the engine out doesn...   Sep 6 2018, 07:29 AM
HerdofCrickets   [quote name='HerdofCrickets' post='2646011' date=...   Sep 6 2018, 08:15 AM
TheCabinetmaker   I diagnose Dirk Wright's desease! Prognosi...   Sep 6 2018, 10:05 AM
cuddy_k   Glad you found the video helpful. As long as you...   Sep 6 2018, 10:13 AM
VaccaRabite   If you are waffling on Chris's engine cradle, ...   Sep 6 2018, 11:53 AM
HerdofCrickets   Not waffling at all, it's on my shortlist of t...   Sep 6 2018, 12:04 PM
RoadGlue   Just a quick note that Chris's cradle doesn...   Sep 6 2018, 12:46 PM
HerdofCrickets   As you can tell, the whole "mechanic" th...   Sep 7 2018, 07:40 AM
TheCabinetmaker   What are you gonna do with a hoist?   Sep 7 2018, 08:47 AM
HerdofCrickets   Once I drop the engine onto the jack & plate, ...   Sep 7 2018, 08:59 AM
brant   Or working with n the floor is perfectly acceptabl...   Sep 7 2018, 09:36 AM
TheCabinetmaker   After you remove the trans, get a couple of friend...   Sep 7 2018, 09:38 AM
cuddy_k   Engine stand: https://www.harborfreight.com/1000-...   Sep 7 2018, 11:25 AM
HerdofCrickets   Engine stand: https://www.harborfreight.com/1000...   Sep 7 2018, 11:55 AM
TheCabinetmaker   So, I nailed it on post#13? Imagine that!   Sep 17 2018, 10:16 AM
HerdofCrickets   So, I nailed it on post#13? Imagine that! S...   Sep 17 2018, 10:26 AM
TheCabinetmaker   Get a Haynes manual or the Tom Wilson engine rebui...   Sep 17 2018, 10:34 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:30 AM
