> Valve Adjustment Question, Valve Adjustment Question
HerdofCrickets
post Sep 3 2018, 07:51 PM
So perhaps I'm slightly not overly excited about smashing my hands up there to do the adjustment (ie lazy) but.... I'm about to try my first valve adjustment, is there a reason we don't drop the exhaust out of the way? Seems it'd be MUCH easier without that blocking all the workspace!
HerdofCrickets
post Sep 6 2018, 07:18 AM
Seems like it! Getting the engine out doesn't seem too bad,
This is a great step by step for rookies like me...
https://www.youtube.com/watch?v=FMesGrjgcvg&t=1s
So I guess I'll order the jack adapter and get to work. Not really sure what to do after I get it out, but I'll figure that out when I get it out!
http://tangerineracing.com/tools.htm
Thanks for telling me to stop driving it before it turned into something worse,
DRPHIL914
post Sep 6 2018, 07:29 AM
Dr. Phil
QUOTE(HerdofCrickets @ Sep 6 2018, 09:18 AM) *
yes this jack adaptor is great, it is what i used to remove mine and while it is nice to have a hand to help you , it can be done by yourself. - I just put my motor and transmission back up into place this past weekend, and only issue i had was clearance with the fuel injection rails on each side- it would clear more easily if you disconnect those - just make sure you also disconnect the ground strap that goes from the back ofhte transmission to the underside of the trunk.
HerdofCrickets   Valve Adjustment Question   Sep 3 2018, 07:51 PM
worn   So perhaps I'm slightly not overly excited ab...   Sep 3 2018, 08:14 PM
Dave_Darling   Just to note that there is a difference between ...   Sep 3 2018, 08:50 PM
HerdofCrickets   Just to note that there is a difference between ...   Sep 3 2018, 09:44 PM
cary   I think we should call it valve clearance inspecti...   Sep 3 2018, 09:46 PM
TheCabinetmaker   Removing the exhaust to adjust valves is kinda lik...   Sep 4 2018, 06:07 AM
falcor75   I'd rather pull the motor and gearbox than pul...   Sep 4 2018, 06:11 AM
HerdofCrickets   Good deal. I was looking for an easy way out but ...   Sep 4 2018, 08:01 AM
cuddy_k   If there's anything else you're thinking a...   Sep 4 2018, 08:29 AM
HerdofCrickets   If there's anything else you're thinking ...   Sep 4 2018, 08:54 AM
Bartlett 914   If there's anything else you're thinking...   Sep 4 2018, 09:37 AM
HerdofCrickets   valves make tapping sounds. if there is a knocki...   Sep 4 2018, 09:46 AM
TheCabinetmaker   Not a valve adjustment problem. Dropped valve seat...   Sep 4 2018, 09:55 AM
billh1963   Not a valve adjustment problem. Dropped valve sea...   Sep 4 2018, 10:26 AM
cuddy_k   :agree: but I hope we're wrong.   Sep 4 2018, 10:49 AM
HerdofCrickets   :agree: but I hope we're wrong. Well me to...   Sep 4 2018, 12:02 PM
brant   :agree: but I hope we're wrong. Well me t...   Sep 4 2018, 01:01 PM
billh1963   Adjust your valves then if the noise still exist...   Sep 4 2018, 01:33 PM
Dave_Darling   Hopefully you are not dropping a valve seat most ...   Sep 4 2018, 04:36 PM
HerdofCrickets   Finally got the stupid cover off. My feeler gauge...   Sep 4 2018, 08:09 PM
TheCabinetmaker   How about the other side?   Sep 4 2018, 11:26 PM
Porschef   :agree: Yes, there are 4 more on the other side....   Sep 5 2018, 04:03 AM
HerdofCrickets   :agree: Yes, there are 4 more on the other side...   Sep 5 2018, 07:22 AM
brant   did You find each cylinder’s tdc? Sorry dumb qu...   Sep 5 2018, 07:17 AM
falcor75   Yup, Passenger side is for cylinder 3 and 4, drive...   Sep 5 2018, 07:36 AM
bdstone914   Couple of tips. To unclip the bale runs a shop to...   Sep 5 2018, 08:02 AM
HerdofCrickets   Couple of tips. To unclip the bale runs a shop t...   Sep 5 2018, 08:10 AM
TheCabinetmaker   And that is why I won't remove heat exchangers...   Sep 5 2018, 08:10 AM
cary   Here's some good reading. https://www.pelicanp...   Sep 5 2018, 08:28 AM
brant   You have to put them at TDC to see whether you hav...   Sep 5 2018, 09:09 AM
HerdofCrickets   Drivers side.... I struggled for about 30 minutes ...   Sep 5 2018, 08:36 PM
TheCabinetmaker   Time for your first engine drop.   Sep 5 2018, 09:18 PM
HerdofCrickets   Seems like it! Getting the engine out doesn...   Sep 6 2018, 07:18 AM
DRPHIL914   Seems like it! Getting the engine out doesn...   Sep 6 2018, 07:29 AM
HerdofCrickets   [quote name='HerdofCrickets' post='2646011' date=...   Sep 6 2018, 08:15 AM
TheCabinetmaker   I diagnose Dirk Wright's desease! Prognosi...   Sep 6 2018, 10:05 AM
cuddy_k   Glad you found the video helpful. As long as you...   Sep 6 2018, 10:13 AM
VaccaRabite   If you are waffling on Chris's engine cradle, ...   Sep 6 2018, 11:53 AM
HerdofCrickets   Not waffling at all, it's on my shortlist of t...   Sep 6 2018, 12:04 PM
RoadGlue   Just a quick note that Chris's cradle doesn...   Sep 6 2018, 12:46 PM
HerdofCrickets   As you can tell, the whole "mechanic" th...   Sep 7 2018, 07:40 AM
TheCabinetmaker   What are you gonna do with a hoist?   Sep 7 2018, 08:47 AM
HerdofCrickets   Once I drop the engine onto the jack & plate, ...   Sep 7 2018, 08:59 AM
brant   Or working with n the floor is perfectly acceptabl...   Sep 7 2018, 09:36 AM
TheCabinetmaker   After you remove the trans, get a couple of friend...   Sep 7 2018, 09:38 AM
cuddy_k   Engine stand: https://www.harborfreight.com/1000-...   Sep 7 2018, 11:25 AM
HerdofCrickets   Engine stand: https://www.harborfreight.com/1000...   Sep 7 2018, 11:55 AM
TheCabinetmaker   So, I nailed it on post#13? Imagine that!   Sep 17 2018, 10:16 AM
HerdofCrickets   So, I nailed it on post#13? Imagine that! S...   Sep 17 2018, 10:26 AM
TheCabinetmaker   Get a Haynes manual or the Tom Wilson engine rebui...   Sep 17 2018, 10:34 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 08:28 AM
