> Parking brakes on 996 turbo brakes?, I need to add parking brakes on my 914-6
Alfy
post Sep 6 2018, 08:00 AM
Hi
This is my first "help" thread on the 914 world (IMG:style_emoticons/default/smile.gif)
I have bought a 914-6 that was previously a very active 914-6 in the USA (called "Wild 6")
I need to get the car road legal here in Norway, and the most important thing I need to do is to add a parking brake/hand brake.
The car has (I think..) brakes from a 996 turbo.
What would be the best option?
Add two extra calipers? is it possible to add a more standard parking brake solution with brake pads inside the brake disc?
Anybody else out there who has done the job before me, or can point in the best direction?
All help is appreciated
Thanks
Alf K Larsen
Steve
post Sep 7 2018, 07:34 AM
The biggest hassle is welding the angle iron parking brake stop to the trailing arm. After that it’s just grinding down the sides for the 911 parking brake assembly to slide over. On my car I just modified two 914 clutch cables for the e-brake cables, but that was before Tangerine made adapters. Others have welded a stop to the shoe assembly, but that will not hold up during an emergency stop. It will work fine as a parking brake. Compare the 911 trailing arm, it has a beefy stop, so you can apply the emergency brake at speed and not have to worry about the shoe assembly braking loose.
I’m running Boxster calipers front and rear on my car.
Alfy   Parking brakes on 996 turbo brakes?   Sep 6 2018, 08:00 AM
Steve   Check out the how to threads. http://www.914world....   Sep 6 2018, 08:06 AM
tomeric914   From my build thread, I created a crankarm, welded...   Sep 6 2018, 09:28 AM
Alfy   Thanks guys! :worship: I need to get under m...   Sep 7 2018, 01:00 AM
bdstone914   Thanks guys! :worship: I need to get under ...   Sep 7 2018, 06:13 AM
Steve   The biggest hassle is welding the angle iron parki...   Sep 7 2018, 07:34 AM
GeorgeRud   Back in the day, George Vellios made an adapter th...   Sep 7 2018, 09:14 AM
Retroracer   Alf - worth posting some pics here to show what yo...   Sep 7 2018, 09:59 AM
Alfy   Thanks a lot guys! All you help is highly appr...   Sep 10 2018, 01:07 AM
Mueller   Thanks a lot guys! All you help is highly app...   Sep 10 2018, 08:10 AM
Alfy   [quote name='Alfy' post='2647324' date='Sep 10 20...   Sep 11 2018, 12:01 AM
ClayPerrine   Thanks a lot guys! All you help is highly app...   Sep 10 2018, 10:08 AM
Alfy   Thanks a lot guys! All you help is highly ap...   Sep 11 2018, 12:07 AM
burton73   I had E at PMB Performance prep my parking brake f...   Sep 10 2018, 11:26 AM
Alfy   I had E at PMB Performance prep my parking brake ...   Sep 11 2018, 12:16 AM
ChrisFoley   :wttc: ... This seems to be the best option fo...   Sep 11 2018, 06:55 AM
Alfy   :wttc: ... This seems to be the best option f...   Sep 12 2018, 12:56 AM
IronHillRestorations   I found a set of used 911 E brakes, and then I got...   Sep 10 2018, 11:58 AM
porschetub   My set-up done by PO has no stops for the shoes,th...   Sep 11 2018, 02:44 PM
wndsrfr   I'd take a hard look at using the Wilwood spot...   Sep 11 2018, 07:56 PM
Alfy   I'd take a hard look at using the Wilwood spo...   Sep 12 2018, 01:16 AM
andys   I'd take a hard look at using the Wilwood spo...   Sep 12 2018, 09:08 AM
TravisNeff   That's Andy Schermully's old car. He took...   Sep 11 2018, 07:58 PM
Alfy   That's Andy Schermully's old car. He too...   Sep 12 2018, 01:20 AM
burton73   Marty – AT MSDS has these spot calipers on his T...   Sep 12 2018, 10:09 AM
Alfy   Had a quick inspection in the workshop yesterday. ...   Sep 13 2018, 12:38 AM
burton73   You are all set. Put some new bushings and stainle...   Sep 15 2018, 02:41 PM
- Lo-Fi Version Time is now: 1st August 2025 - 04:32 PM
