No brake lights! |
No brake lights! |
cooper951 |
Sep 14 2018, 08:38 AM
Member Group: Members Posts: 83 Joined: 30-September 15 From: Central Missouri Member No.: 19,219 Region Association: None |
So I took the teener for inspection this morning and no brake lights. That's the bad news. The good news is no one has slammed into me from the rear up to this point. Since I doubt it is a bulb issue, where to start? Is there a brake light switch, and where is it located? TIA.
Localboy808 |
Sep 14 2018, 09:10 AM
Member Group: Members Posts: 185 Joined: 17-July 16 From: Palmdale, Ca Member No.: 20,194 Region Association: None |
So I took the teener for inspection this morning and no brake lights. That's the bad news. The good news is no one has slammed into me from the rear up to this point. Since I doubt it is a bulb issue, where to start? Is there a brake light switch, and where is it located? TIA. Funny I have the same issue right now. Havent had the time to really get into figuring it out yet. The switch is at the master cylinder. Wire going into it and wire leaving it. I have no voltage at the switch so I need to break out a schematic and see where that 12v comes from. I think it gets it from the fuse panel. |
barefoot |
Sep 14 2018, 10:43 AM
Senior Member Group: Members Posts: 1,279 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
[/quote] The switch on the master cylinder is not the brake light switch, it's a safety switch to show bad master cylinder. the brake light switch is in the cockpit in behind the pedal board and has a lever that the brake pedal actuates. |
Localboy808 |
Sep 14 2018, 09:22 PM
[quote name='barefoot' date='Sep 14 2018, 11:43 AM' post='2648806']
Funny I have the same issue right now. Havent had the time to really get into figuring it out yet. The switch is at the master cylinder. Wire going into it and wire leaving it. I have no voltage at the switch so I need to break out a schematic and see where that 12v comes from. I think it gets it from the fuse panel. [/quote] The switch on the master cylinder is not the brake light switch, it's a safety switch to show bad master cylinder. the brake light switch is in the cockpit in behind the pedal board and has a lever that the brake pedal actuates. [/quote] Thanks for the correction! I forgot that! Now I know where to start looking! Scott |
Lo-Fi Version | Time is now: 4th June 2024 - 04:35 PM |
