> optima battery
wackii
post Sep 18 2018, 02:08 PM
does anyone know the correct optima battery for 73 2.0 914 thanks Wac
or does anyone know if the odyssey pc1200 fit?
Ansbacher
post Sep 18 2018, 07:19 PM
Mount it sideways and you will NEVER have a clearance problem closing the engine lid.
Ansbacher
petza914
post Sep 18 2018, 11:00 PM
QUOTE(Ansbacher @ Sep 18 2018, 05:19 PM) *
Ansbacher
If the positive terminal is as close to the metal battery pan as the negative one shown, that's not a good setup (can't see under the white cover). Also, how is the battery secured in that fashion to not slide back and forth in the pan?
As far as Optima longevity, I have one in each of my 997s, in my 928, in my 914, and in my DD pickup. The one in my 914 has been in there since 2000, yup, 18 years. Granted it isn't driven all that often and is always connected to a Battery Tender charger/maintainer, but that's still a remarkably long time for any battery. The one in my silver 997 has been in there since 2013, as has the one in the pink 997, and the one in my truck even longer. Even run the Blue Tops in the boat.
For the Cayenne, because it takes a much larger battery, I went with a Napa Gold AGM. I'll never buy another lead acid battery again.
Here's the setup in the 914
wackii   optima battery   Sep 18 2018, 02:08 PM
mepstein   34 or 34-R. Can't remember which.   Sep 18 2018, 03:11 PM
VaccaRabite   Don’t buy an Optima. They suck these days. If y...   Sep 18 2018, 05:41 PM
wackii   Don’t buy an Optima. They suck these days. If ...   Sep 18 2018, 05:46 PM
somd914   Don’t buy an Optima. They suck these days. If...   Sep 18 2018, 06:37 PM
JamesM   [quote name='wackii' post='2649961' date='Sep 18 ...   Sep 23 2018, 11:29 AM
don-6   I use the Red Top 35. I got twelve years out of th...   Sep 18 2018, 05:47 PM
wackii   I use the Red Top 35. I got twelve years out of t...   Sep 18 2018, 06:02 PM
tomeric914   Group 35 is what I used, probably because they did...   Sep 18 2018, 05:55 PM
Bartlett 914   If you get a red top Optima, be sure to get a Ba...   Sep 19 2018, 07:22 AM
mepstein   If you get a red top Optima, be sure to get a B...   Sep 19 2018, 07:34 AM
don-6   No mods required. In the picture you can see the b...   Sep 18 2018, 06:12 PM
wackii   No mods required. In the picture you can see the ...   Sep 22 2018, 06:46 PM
pete000   Been using the Optima red top 35 in both my 914s f...   Sep 18 2018, 06:53 PM
Ansbacher   Mount it sideways and you will NEVER have a cleara...   Sep 18 2018, 07:19 PM
petza914   Mount it sideways and you will NEVER have a clear...   Sep 18 2018, 11:00 PM
euro911   I am also a fan of the Odyssey PC925. Bought one f...   Sep 19 2018, 12:43 AM
michael7810   This is the Odyssey I installed using PMS’s adap...   Sep 19 2018, 05:33 AM
mepstein   I use a battery tender junior. $25 and works ...   Sep 22 2018, 07:55 PM
petza914   Wouldn't you know it... the Optima in my 914 c...   Sep 22 2018, 08:07 PM
ClayPerrine   We have run Optima batteries in every one of our v...   Sep 23 2018, 10:05 AM
Larmo63   I have had good experiences with Optima batteries....   Sep 23 2018, 11:16 AM
petza914   New Optima Yellow top is on the bench getting a fu...   Sep 23 2018, 11:58 AM
jim_hoyland   Is the 680 considered good for a 914-4 in terms of...   Sep 23 2018, 12:33 PM
VaccaRabite   Is the 680 considered good for a 914-4 in terms o...   Sep 23 2018, 07:17 PM
napasteve   I've only had the Optima for 2 years. No compl...   Sep 23 2018, 07:05 PM
orthobiz   I have good luck with the Optimas over 10 years no...   Sep 23 2018, 07:23 PM
- Lo-Fi Version Time is now: 14th August 2025 - 01:28 AM
