> 1971 914-4 won't fire, car has been sitting since 2002
sgtjelange
post Sep 19 2018, 10:02 AM
Hello, my name is Jon and I am new to this forum or any forum for that matter. I came here because I really need help. I have a 1971 914 1.7L with original paint and original fuel injection. I purchased the car in 1998 while in CA in the USMC, used the car daily until 2002 when I was discharged and parked the car in a barn MI till 2018. I just started working on the car and have replaced the plugs, wires, cap, rotor, points, condenser, coil, fuel filter, fuel, fuel pump, oil, oil filter, and fuel injectors. I checked the timing by setting #1 to TDC and used the mark on the distributor aligned with the rotor. I set the points to .016 and adjusted the fuel pressure to 28 PSI.
My problem is that the car just won't start. There is good spark at every cylinder. while cranking the fuel pump holds 28 PSI attempts to fire for about a 1/2 second and then nothing. But if I pump the the pedal while starting it will kind of stay running but barely, the fuel pressure will drop, and it will backfire through the manifold. I hate to sound desperate because this whole thing is my fault for waiting so long but my daughter is a senior on homecoming court and said if that ever happened she wanted to parade in my porsche. Well that day actually came Friday 9/21/18! and now I am scrambling. I procrastinated way to long on this car. Please help if you can. I would appreciate it.
Jon
DRPHIL914
post Sep 19 2018, 10:35 AM
Dr. Phil
QUOTE(sgtjelange @ Sep 19 2018, 12:02 PM) *
Jon
if the fuel pressure is dropping then your pump might not be working OR easier yet upon putting the tank back in there is a pinched line, if too long they will bend and pinch when putting the pump in- I had this happen the first time I reinstalled my pump too- that might be all it is! pull tank up a bit with out disconnecting anything and see if it starts and runs, if it does there is your issue!
sgtjelange
post Sep 19 2018, 11:31 AM
I actually found a MPS on ebay from a company in MI and they are going to overnight it. I have my fingers crossed. Thank you very much!
Jon
[/quote]
DRPHIL914
post Sep 19 2018, 11:34 AM
Dr. Phil
[quote name='sgtjelange' date='Sep 19 2018, 01:31 PM' post='2650225']
Jon
[/quote]
[/quote]
Great! (IMG:style_emoticons/default/popcorn[1].gif)
sgtjelange
post Sep 19 2018, 11:43 AM
It is only dropping when pumping the pedal to keep it firing (can't say running), but on regular cranking it holds 28 PSI like it's welded there.
Jon
[/quote]
[/quote]
[/quote]
- Lo-Fi Version Time is now: 2nd April 2026 - 01:08 PM
