GB door stay pin. Is your door popping?GB closes 10/4/18 midnight, $8 a set of 2 or $44 for entire kit- both doors including these |
Mikey914 |
Sep 19 2018, 11:42 PM
The rubber man Group: Members Posts: 12,677 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So, a problem part is the door pins that do wear. These can make a popping sound when the door is opened. We have machined these to be slightly larger so that they will take up some slop in the old door stay arms if you are not doing a complete rebuild. They make a very tight fit on the new arms and will not allow the pin to shift in the new arms (the old pins tend to corrode and wear over time).
So you can buy just the pins at $8 a set These just came back from plating (note the current picture shows unplated I'll update tomorrow) and we will be kitting up starting tomorrow. Best deal if you do on have these is the entire kit at $44. This will do both doors and includes the standard kit shown + 2 new pins. SO Who's interested? Attached thumbnail(s) Attached image(s) |
Olympic 914 |
Sep 20 2018, 07:27 AM
Group: Members Posts: 1,675 Joined: 7-July 11 From: Pittsburgh PA Member No.: 13,287 Region Association: North East States |
1 set of the pins for me also.
I see there are no holes for cotter pins, or grooves for a snap ring clip. do the pins just drop in there and stay? I don't have the original pins, I have bolts w/ nuts in there now. and they are too loose. |
Lo-Fi Version | Time is now: 7th June 2024 - 09:09 PM |
