| amfab |
Sep 22 2018, 09:49 PM
Member ![]() ![]() Group: Members Posts: 401 Joined: 17-May 16 From: Los Angeles Member No.: 20,004 Region Association: None
I have a couple of questions about my engine compartment for my 74 3.2 six conversion—what to I need to keep and what can I get rid of? The passengers engine shelf needs replacing, and the driver’s side needs a little work.
While I am in working on the engine compartment what can I get rid of for a cleaner installation? On the drivers side I have removed the shelf brackets for the relay plate, and the bracket for the blower. Should I remove the ground stud that comes out? Is there anything I should weld shut on that side while I am fixing up the engine shelf? On the passenger’s side—same question. Also, do I need that angled piece of sheetmetal/bracket that spans the indentation on the upper part of the inner suspension ear? My four-cyl was not stock when I got it and I do not know what that is for. TIA -Andrew |
| mepstein |
Sep 23 2018, 09:16 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,924 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I know Sir Andy mounted his 3.6 DME under the dash. I think mine will fit but I don't remember if I tried. It's just sitting on the passenger floor since I still need to clean up the wiring.
I don't know off hand what the dimple is for. |
amfab 914-6 conversion engine compartment Sep 22 2018, 09:49 PM
ConeDodger No four mounts.
No relay board. Sep 22 2018, 09:57 PM
Dave_Darling The bracket on the right side of the engine bay is... Sep 22 2018, 10:43 PM
amfab Thanks Dave, I forgot to mention the four mounts a... Sep 22 2018, 11:47 PM
Thanks Dave, I forgot to mention the four mounts ... Sep 23 2018, 06:07 AM
amfab
Thanks Dave, I forgot to mention the four mounts... Sep 23 2018, 09:08 AM
porschetub
The bracket on the right side of the engine bay i... Sep 23 2018, 12:53 AM
Dave_Darling
I know Sir Andy mounted his 3.6 DME under the das... Sep 23 2018, 09:44 PM
mb911 This is how I reinforced this area. Sep 23 2018, 09:52 AM
amfab
Thanks Ben,... Sep 23 2018, 10:13 AM
mb911
Thanks Ben... Sep 23 2018, 10:28 AM
Larmo63 I left the /4 engine mounts intact, I think that t... Sep 23 2018, 10:18 AM
Steve As Mepstein said, I also dumped the relay board fo... Sep 23 2018, 10:28 AM
mepstein If mine doesn't go under the dash, I was also ... Sep 23 2018, 10:09 PM
porschetub Will retract what I said cause I didn't read p... Sep 23 2018, 11:36 PM
Will retract what I said cause I didn't read ... Sep 24 2018, 06:36 AM![]() ![]() |
Lo-Fi Version | Time is now: 5th October 2026 - 04:42 AM |
