Went to change a broken clutch cable, discovered car has cancer, bit emotional at this moment. Knew it was coming, didn't expect the scope |
davebrossi |
Sep 8 2018, 04:39 PM
Member Group: Members Posts: 52 Joined: 6-December 11 From: Idaho Falls, Idaho Member No.: 13,868 Region Association: None |
Hi All,
I prefer most often to lurk, but after a spin to a nearby autobody shop about filling in some rock chips on the rear fender flairs of the clown car netted me a 13,500 estimate, I've been a little on edge for rust. This morning I set out to change the clutch cable which had snapped last weekend. As I was getting myself situated I noticed some of the undercoating seemed more...flaky than usual. I moved my finger towards it, brushed it and off it came! along with another small piece. I was now staring in disbelief at a mixture of pink body filler and carpet. OK! I told myself, this seems relatively minor, let's just clean the area, I can fix this, maybe not the best way, but I can!. That was five hours ago. As I worked I realized I needed to see where the damage was on the interior, so I removed the carpeting. Once again, I spied a familiar orange tinge... under the urethane installed at the factory. I started working with a chisel and hammer. What was a small hole was in fact a seam running along and right up to the driver's side right seat bracket. The concrete below glared at me menacingly. The clown car (my 914-6) was the result of an venture from a forum member offering turnkey restoration of 914s. I have no interest in flaming or anything mean, so I will not say who, and that's not a challenge either, since frankly all of this was beneath urethane, and said individual cleaned, primered and properly painted surfaces all the way to the old urethane on the floor pans. but it is worth mentioning because rather than spiral down the inception styled road of 'oh god I'm doomed, DOOOOOMMMMED!' I sat back and thought about what they -had- restored and what I had to go back and work on. The interior of the door panels was rusty, I sanded, sealed with POR15, clear coat has a craze to it, but stable and looks fine. Small side sail bumps. Originally thought body filler, probably tin worm, but unlikely to fail while driving and drag me half out of the bottom of the car. Longitudinals, hell hole both extensively reviewed during restoration, both are clear. I don't see bubbles all over the car, and the 13500 was with a note saying "we don't serve yer kind round these parts try these guys since they do antiques" from a shop filled with classic american muscle cars and more of a 'get lost' message, which I understand because scope creep is real. I want to believe this is one of those typical stories where I don't wind up with the Porsche 914 equivalent of "you have died of dysentery" on the Oregon Trail PC game, but I also have to face up to the fact that I will have to acquire new front and rear floor pans. Happily they can be ordered from Pelican without much fuss (the available weld in panels for the 914 is really REALLY a reason I love them in an odd sort of way.) I know I have to invest in a welder as I lack the skills. I want to prepare the area as best as humanly possible because A.) I believe in being a good steward and B.) I'm afraid while I'm happy to pay for their services, I am cheap and would prefer to do the prep work myself. Advice (maybe prayers?) is/are appreciated, but I will be searching threads and educating myself accordingly as I know I need to. in the meantime, here's some NSFW Porsche Floor pan gore; the initial discovery and early cleaning The point at which I realize I should probably look at the top end of things. because regrettably I am a millenial, I wanted to show off my PPE for working with fiberglass and sanding. The moment my heart sank, the colour drained out of my face, and I had to go have a little sit down. (IMG:style_emoticons/default/barf.gif) This is the extent of the rot. You can see the garage floor clearly a menacing glare fixed on it's eyeball-less face :E! I wont blame the consumption of Hubert's lemonade, wait, no, yes I'll blame it for the rust after all! The start of (and at which point I realized that the floor pans were toast on both sides) the surface rust on the other side. I'll admit it was heartbreaking to discover. I wanted to give up and throw it all away, sell it and be done with it. But then again, new front and rear floor panels are made for a reason, and the last undiscovered country (Star Trek) both my father and I were starting into was body work in the last couple years. I'm hoping I'm not right thinking this will require the selling of one of both a kidney and a lung, frankly I have no idea, though (in a phrase I use talking with my employers often) I look forward to the opportunities it will afford me moving forward. Bonus points here in how my dad managed to cause the usual reaction that always happened when there was a setback and he had to tell mom one last time. (IMG:style_emoticons/default/chair.gif) |
burton73 |
Sep 24 2018, 02:52 PM
burton73 Group: Members Posts: 3,540 Joined: 2-January 07 From: Los Angeles Member No.: 7,414 Region Association: Southern California |
Dave,
Take your time with this. It takes a lot of time to drill out all the welds that hold a new pan in. You cannot be rushed on doing it or all kinds of problems can happen. The welding needs to be slow as well so things do not warp. There are a number of ways to do this but you do need to do it slow. Very slow. My younger self would not have taken this job as a weekend job. Anything can screw up and if you are at a friend’s lift they may need you off. I think one weekend to drill all those wells out and then all the clean-up and prep. I had the body shop next door do my pan and do not remember just how much it cost in hours. Do you have a daily driver? I remember when my daily driver was my 914 2.0 back in 79 when I was in my 20s. It made me sick worrying if my car would be running or not. I am saying really sick. Pictures of my new pan getting welded in. The picture of old pan when I bought my car. Picture of pan after we cleaned all the tar out and I went to town with a screwdriver showing me just what was not solid. In picture of old pan look carefully in the center section where more PO used a u clamp to hold down the clutch tube. There was a U Clamp on the side of the center channel also holding in the tube up front next to the driver’s seat. I hope this helps you and does not send you down a very dark path of getting in too deep on your car without help. Bob B |
davebrossi |
Sep 24 2018, 05:57 PM
Dave, Take your time with this. It takes a lot of time to drill out all the welds that hold a new pan in. You cannot be rushed on doing it or all kinds of problems can happen. The welding needs to be slow as well so things do not warp. There are a number of ways to do this but you do need to do it slow. Very slow. My younger self would not have taken this job as a weekend job. Anything can screw up and if you are at a friend’s lift they may need you off. I think one weekend to drill all those wells out and then all the clean-up and prep. I had the body shop next door do my pan and do not remember just how much it cost in hours. Do you have a daily driver? I remember when my daily driver was my 914 2.0 back in 79 when I was in my 20s. It made me sick worrying if my car would be running or not. I am saying really sick. Pictures of my new pan getting welded in. The picture of old pan when I bought my car. Picture of pan after we cleaned all the tar out and I went to town with a screwdriver showing me just what was not solid. In picture of old pan look carefully in the center section where more PO used a u clamp to hold down the clutch tube. There was a U Clamp on the side of the center channel also holding in the tube up front next to the driver’s seat. I hope this helps you and does not send you down a very dark path of getting in too deep on your car without help. Bob B Hi Again Bob! Honestly nothing will happen fast as much as I want it to. I'm not even going to contact the welder until I'm comfortable I've done what I consider appropriate prep. This includes checking the longitudinals (haven't yet) and whatever else anyone chimes in to inspect. I am learning, but one thing I am always in need of being reminded to, is slow it down a notch (That's how I got to do the IMS Bearing replacement not once but twice on my 986, huzzah!) Having seen the Restoration Design prep videos, things like seat hinges, the jack points, and other panels associated will likely be replaced if I can swing it as I'd like this to be the only time I mess with the floor pans for as long as possible, and I have seen how involved that is. Having zero welding ability makes it impossible for me alone, but in steps, hopefully I can work towards getting there. I have a heated garage, I've got what I think will be the right tools to work through prep, and as long as wiser minds continue to remind me, I am not rushing into anything. Not that I want to, but to confirm my initial assumption, for the sake of the welder's safety this car really does need to be on a lift, yes? Local body shops wont touch the car, but going on my own, whatever 'solution' I work out safety's number one here, proper prep second. My daily driver's a 2014 Mazda CX5. It's boring, but one thing it is also is reliable. |
Lo-Fi Version | Time is now: 3rd June 2024 - 02:29 PM |
