Replacement oil sender question |
dgraves |
Sep 24 2018, 03:56 PM
1974 914 2.0 Group: Members Posts: 180 Joined: 6-June 16 From: Montana Member No.: 20,076 Region Association: Rocky Mountains |
My '74 2.0 914 has a 911 dash instrument panel with a Druck Pressure gauge. I have confirmed that my oil pressure sender unit has failed. I'm assuming that a Druck oil pressure gauge and sender is not standard factory equipment for a 914. How do I know what sender to buy?
Thanks, guys. I really miss my pressure gauge not working. Dan |
porschetub |
Sep 25 2018, 02:18 PM
Advanced Member Group: Members Posts: 4,704 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
From memory the 1 to 5bar unit wasn't used for long on ROW 911's, so of course the 80psi sender is the correct one,shop around the senders can range from crazy expensive to reasonable,I'am running a 150psi VDO dual function one that has the higher pressure warning of 10psi,good peace of mind solution IMO.
Bought mine on ebay for $35 some time ago and have had no issues,only thing I didnt like was the plastic thumbscrews so replaced them with small nylock nuts. |
dgraves |
Sep 25 2018, 10:15 PM
From memory the 1 to 5bar unit wasn't used for long on ROW 911's, so of course the 80psi sender is the correct one,shop around the senders can range from crazy expensive to reasonable,I'am running a 150psi VDO dual function one that has the higher pressure warning of 10psi,good peace of mind solution IMO. Bought mine on ebay for $35 some time ago and have had no issues,only thing I didnt like was the plastic thumbscrews so replaced them with small nylock nuts. Here's a picture of the sender. 80psi or 150psi? Curious on the Druck gauge the range is 1 to 5, how does this range relate to the 80 or 15psi? |
jcd914 |
Sep 25 2018, 10:36 PM
Advanced Member Group: Members Posts: 2,081 Joined: 7-February 08 From: Sacramento, CA Member No.: 8,684 Region Association: Northern California |
From memory the 1 to 5bar unit wasn't used for long on ROW 911's, so of course the 80psi sender is the correct one ,shop around the senders can range from crazy expensive to reasonable, Here's a picture of the sender. 80psi or 150psi? Curious on the Druck gauge the range is 1 to 5, how does this range relate to the 80 or 15psi? ddgraves provided the answer. Your gauge is 0 to 5 bar which is roughly 0 to 80 psi. Approx 15 psi per each bar. Jim |
Lo-Fi Version | Time is now: 4th June 2024 - 08:46 PM |
