Broke down in Bakersfield Ca, Need side shift rod for side shift or welding shop |
MJHanna |
Sep 25 2018, 10:13 PM
Does this 911 make my butt look big? Group: Members Posts: 805 Joined: 23-January 03 From: Lowry Crossing, Texas Member No.: 185 |
On way to Rennsport
Weld back by coupler going into transmission broke the weld needed another rod or a welding shop in area Thanks Mark |
76-914 |
Sep 26 2018, 07:40 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,508 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
I'm 30 S of you with transportation and a lift if needed. I can drive you to Bruce's, grab a new rod and have you going quickly. LMK here. I'll watch this thread this morning in case. Kent
bdstone914 |
Sep 26 2018, 08:14 AM
bdstone914 Group: Members Posts: 4,535 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I'm 30 S of you with transportation and a lift if needed. I can drive you to Bruce's, grab a new rod and have you going quickly. LMK here. I'll watch this thread this morning in case. Kent If you get is welded it looks like the solid rod is loose from the tube. There is a clocking of that shaft with the hole to position it to the tube. If it is off nothing will line up. I have a jig that I use to set the shaft to tube orientation. Those cone screws are supposed to be replaced. At least clean them and use some locktite Kent. He is in Bakersfield. Are you heading that way? Call me at 951 536 7478 if you want a rod. We can work out payment later. Bruce @76-914 @MJHanna |
Lo-Fi Version | Time is now: 7th June 2024 - 09:15 AM |
