identify front shocks |
JFG |
Sep 23 2018, 05:19 AM
Senior Member Group: Members Posts: 686 Joined: 7-April 16 From: Wales Member No.: 19,869 Region Association: None |
i'm looking at new front shocks for my 74 but all the images are of just straight damper units. i know generic library images are used often but i'm a tad confused.
the picture shows the hub/stub axle is welded to the damper. i have found an image of this but it's listed as 911. can someone explain what i have / should have? the rotors are 4 stud all around. |
JFG |
Sep 26 2018, 10:02 AM
thanks for that info. does the shock cartridge just sit inside the outer tube or does it screw in?
mepstein |
Sep 26 2018, 10:11 AM
914-6 GT in waiting Group: Members Posts: 19,307 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
thanks for that info. does the shock cartridge just sit inside the outer tube or does it screw in? It drops down inside and a lock ring tightens down over top of the cartridge. You con use a lock ring spammer or a pipe wrench to remove. Sometimes it can be very stubborn and some heat (propane or map gas) on the tube near the top can aid with removal. |
Lo-Fi Version | Time is now: 2nd June 2024 - 02:04 AM |
