Re-Keying Door Locks, Too Many Keys |
Spoke |
Nov 19 2004, 03:46 PM
Jerry Group: Members Posts: 6,991 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
I've heard that a door lock can be re-keyed by changing the pieces in the lock but I've not seen the kit or the parts anywhere on the web. I'm tired of using one key for the door and another for the ignition. Also neither key fits the passenger door and trunk. Can the door and trunk locks be re-keyed?
Thanks, Spoke |
Ctrout |
Nov 19 2004, 05:22 PM
Member Group: Members Posts: 377 Joined: 20-May 04 From: Mountain Home, ID. Member No.: 2,091 |
Yes, you should be able to do it yourself if you have enough of the right pins. I think there are like 4 or 6 different sizes, numbered accordingly. Just write the pin sequence for the cylinder that is keyed with the key you want to use then rearrange the pins in the other cylinders to match. I think that Pelican or someone even has an article on how to do it. It's really easy.
Lo-Fi Version | Time is now: 6th June 2024 - 10:05 PM |
