GB door stay pin. Is your door popping?GB closes 10/4/18 midnight, $8 a set of 2 or $44 for entire kit- both doors including these |
Mikey914 |
Sep 19 2018, 11:42 PM
The rubber man Group: Members Posts: 12,678 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
So, a problem part is the door pins that do wear. These can make a popping sound when the door is opened. We have machined these to be slightly larger so that they will take up some slop in the old door stay arms if you are not doing a complete rebuild. They make a very tight fit on the new arms and will not allow the pin to shift in the new arms (the old pins tend to corrode and wear over time).
So you can buy just the pins at $8 a set These just came back from plating (note the current picture shows unplated I'll update tomorrow) and we will be kitting up starting tomorrow. Best deal if you do on have these is the entire kit at $44. This will do both doors and includes the standard kit shown + 2 new pins. SO Who's interested? Attached thumbnail(s) Attached image(s) |
North Coast Jim |
Sep 30 2018, 09:48 AM
Member Group: Members Posts: 323 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region |
So, a problem part is the door pins that do wear. These can make a popping sound when the door is opened. We have machined these to be slightly larger so that they will take up some slop in the old door stay arms if you are not doing a complete rebuild. They make a very tight fit on the new arms and will not allow the pin to shift in the new arms (the old pins tend to corrode and wear over time). So you can buy just the pins at $8 a set These just came back from plating (note the current picture shows unplated I'll update tomorrow) and we will be kitting up starting tomorrow. Best deal if you do on have these is the entire kit at $44. This will do both doors and includes the standard kit shown + 2 new pins. SO Who's interested? Since I started this thread and am still looking for a solution I'll take two pins. I already have your kit to rebuild the stays. Hope this works. Do I need to go your site to order ?? |
Lo-Fi Version | Time is now: 8th June 2024 - 02:48 AM |
