Shifter rod question, Shifter rod question |
simonjb |
Sep 30 2018, 01:08 PM
KiwiMan Group: Members Posts: 563 Joined: 18-October 16 From: Stamford, Connecticut Member No.: 20,505 Region Association: North East States |
I've been installing the shift rod on my 914 restoration.
So I managed to get the rear rod connected where it connects to the transmission mechanism. However, when i went to connect the rear rod to the front rod just inside the engine compartment, (The connection in the example photo below) I noticed that the hole that the screw goes into is on the TOPt side of the rod, and not the BOTTOM where the screw from the rear rod would attach. It looks like the rod from the front shifter is upside down. Ugh Is there anyway to deal with this except to open up all the front shift area and turn the rod ? unfortunately all the carpet and center unit has been installed already. I assume drilling a hole in the rod isn't smart? |
simonjb |
Oct 1 2018, 05:51 AM
Chris - you stated in correctly...so I will open up the inside and then loosen the seat and rotate. Thanks all.
Lo-Fi Version | Time is now: 2nd June 2024 - 01:19 PM |
