Brain trust question for hydraulic clutch...., 944 turbo clutch pedal insanity..... |
second wind |
Oct 1 2018, 04:13 PM
Senior Member Group: Members Posts: 857 Joined: 30-December 10 From: Los Angeles, California Member No.: 12,543 Region Association: Southern California |
Hey guys.....please help if you can. Took 1989 944 turbo to Rennsport instead of 914....about 100 in the clutch pedal went down and never came back up. I used my toes to pry it back up and then pumped it to get a shift out of it. Made it to hotel and left parked for two days. Brake reservoir full but forced a bit more in. Somehow had a inch or so of pedal so made the best of it. Last 100 miles back the pedal starts working like perfect and pushes back up like normal. This is a puzzlement to me. Had new brake pads put in week prior and also clutch pedal acted a little funky a month earlier. Any ideas out there? Anyone know what power bleeding is? I would love to figure this out. Have read other forums and guys have replaced master and slave cylinders and still have the same problem. I sure would appreciate an explanation before burning through my money. Thank you very much.
gg |
mb911 |
Oct 1 2018, 05:07 PM
914 Guru Group: Members Posts: 6,883 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Hey guys.....please help if you can. Took 1989 944 turbo to Rennsport instead of 914....about 100 in the clutch pedal went down and never came back up. I used my toes to pry it back up and then pumped it to get a shift out of it. Made it to hotel and left parked for two days. Brake reservoir full but forced a bit more in. Somehow had a inch or so of pedal so made the best of it. Last 100 miles back the pedal starts working like perfect and pushes back up like normal. This is a puzzlement to me. Had new brake pads put in week prior and also clutch pedal acted a little funky a month earlier. Any ideas out there? Anyone know what power bleeding is? I would love to figure this out. Have read other forums and guys have replaced master and slave cylinders and still have the same problem. I sure would appreciate an explanation before burning through my money. Thank you very much. gg Very typical of 944s that have sat or the slave or master cylinder are bad or need bleeding.. Moisture is the issue usually.. |
Lo-Fi Version | Time is now: 9th June 2024 - 10:59 PM |
