rjames |
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 3,971 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest ![]() ![]() |
You'd think that it wouldn't have taken me 11 years to look at the engine code. I have a '75 2.0. Just assumed the engine was original to the car.
Finally looked tonight and saw the following: ![]() So I have a bus engine? (IMG:style_emoticons/default/barf.gif) A 1976-77 2.0 liter Bus, according to the interwebs. Confused because I only see 3 studs on the intakes. If it was a bus engine, shouldn't there be 4 studs? ![]() ![]() What little I do know: PO had the engine rebuilt by a well-known local shop. Was rebuilt with Hydro lifters Oil dipstick located at the top. Engine pulls to 5500 rpm (I've read that bus engines aren't capable of this) I replace the flywheel with a 914 flywheel when I replaced the clutch. I thought I read where the busses use a different flywheel? What do I have, and is there any chance it was built to Porsche 2.0 specs? Now all I can think of is finding a proper engine. (IMG:style_emoticons/default/headbang.gif) |
cgnj |
Senior Member ![]() ![]() ![]() Group: Members Posts: 627 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None ![]() ![]() |
I see late 2.0 heads. Likely 2.0 motor built in a bus case. Hopefully it doesn't have bus pistons.
Carlos |
Lo-Fi Version | Time is now: 15th June 2024 - 08:05 PM |
