Ezcarlift, Lift |
Ezcarlift, Lift |
JoeD |
Oct 3 2018, 06:14 AM
Member Group: Members Posts: 156 Joined: 19-July 15 From: Atlanta, GA Member No.: 18,973 Region Association: South East States |
After years of jacks stands and tight quarters, I finally pulled the trigger on a “lift”. My garage is tight and has a very low ceiling so couldn’t do what I really wanted and put a real lift in; opted for the ezcarlift. It arrived yesterday and within an hour had the car up. I can move it from the garage to the driveway as needed and though only 26” of lift, I am absolutely giddy about the amount of room I now have underneath.
About to re-do the front end (steering rack, tie rod ends, control arm / sway bar bushings etc) and brakes / rotors all around. Plus the undercoat is peeling and needs to be scraped and redone, and lots of other little things need freshening up. This will make life so much easier! |
90quattrocoupe |
Oct 3 2018, 09:11 PM
Member Group: Members Posts: 208 Joined: 4-November 16 From: Long Beach, CA. Member No.: 20,561 Region Association: Southern California |
Once the car is in the air, could one of the cross members be removed, if it was in the way?
Greg W. |
Krieger |
Oct 3 2018, 10:27 PM
Advanced Member Group: Members Posts: 4,723 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
90quattrocoupe |
Oct 5 2018, 11:39 AM
Once the car is in the air, could one of the cross members be removed, if it was in the way? Greg W. Yes. I've done that temporarily. Thanks. Are the cross braces adjustable for width, depending upon the width of the car being lifted? Greg W. |
mgphoto |
Oct 5 2018, 05:43 PM
"If there is a mistake it will find me" Group: Members Posts: 1,339 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Once the car is in the air, could one of the cross members be removed, if it was in the way? Greg W. Yes. I've done that temporarily. Thanks. Are the cross braces adjustable for width, depending upon the wide of the car being lifted? Greg W. The width is adjustable by replacing the cross members with a smaller or larger size. I used a set of cross members 4 inches smaller than normal, I used these rubber pads to support the pan while replacing the passenger side long. Portability, configurability and options makes the EZCarlift the best choice for me. |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:47 PM |
