> Type 4 Store LE-200 Heads, Anyone Used These
Mblizzard
post Oct 9 2018, 03:21 PM
The write up sounds awesome but so is the price. Anyone have experience with these? I am building essentially a 2549. I have some good big valve heads that are ported, 44 intake valves 36 exhaust valves, dual springs, and chromoly retainers but may not flow as well as these. Not looking to build the beast of all engines but I am in so deep it is hard to stop. But $3,700 for heads is steep. Likely not as good but AA has similar heads for just over $2K. I think my current heads may leave some flow on the table but is really hard to justify the money unless someone else has an experience that makes this a requirement.
LE-200
Castings: AMC
Chambers: CNC machined 2.0 914
Chamber Step: 95.0 x 1.0mm *
Plug angle: 2.0 914
Plug size: M12
Valve sizes: 44mm x 38mm by Manley
Springs: Premium dual Crower set for 160lbs seat pressure & 330lbs at .520” valve lift.
Retainers: Crower Chromoly
Keepers: Hardened and ground for clearance
Intake Ports: Fully CNC machined with hand finished details.
Exhaust Ports: Fully CNC machined with hand finishing.
Introduced in 2004, the LE-200’s have become the benchmark for superior high-end performance Type 4 engines. So named because they represent the Leading Edge of technology and the intake ports flowed 200CFM @ .500” valve lift, a value they exceeded by the 2nd version. The exhaust ports average flow is 75-77% of the average intake port flow.
crash914
post Oct 9 2018, 05:35 PM
its a mystery to me
they are expensive, but you get what you pay for.
the springs are beastly. mine rev's up to 7K with no bounce on a high lift reduced base circle cam.
The chambers are matched to LE's pistons if you go with Nickies.
beware that these use 12mm plugs, i.e. motorcycle plugs, smaller diameter, but have a punch.
valves are special, high quality with super strong retainers.
bent one, Len sent me a new one. no head damage, guides are super strong also.
they come with matched intakes. the profile is interesting, valves are unmasked. they flow like crazy.
had these on my 103 motor, blew it up, cleaned up the heads and now they are on my 102 motor.
my head guys here were really impressed when they cleaned up the damage to the one cylinder.
Mblizzard   Type 4 Store LE-200 Heads   Oct 9 2018, 03:21 PM
crash914   they are expensive, but you get what you pay for. ...   Oct 9 2018, 05:35 PM
Mblizzard   they are expensive, but you get what you pay for....   Oct 9 2018, 06:11 PM
Jetsetsurfshop   Contact Len at Hoffman He built me a set of heads ...   Oct 9 2018, 07:15 PM
Mark Henry   They're heads built by Len Hoffman, HAM I...   Oct 9 2018, 07:18 PM
r_towle   Have you had your existing head checked on a flow ...   Oct 9 2018, 07:21 PM
Mblizzard   Have you had your existing head checked on a flow...   Oct 9 2018, 07:56 PM
Jetsetsurfshop   Len outperformed my old heads on the flow bench. I...   Oct 9 2018, 07:33 PM
Mark Henry   Len outperformed my old heads on the flow bench. ...   Oct 10 2018, 08:51 AM
Mblizzard   Len outperformed my old heads on the flow bench....   Oct 10 2018, 08:53 AM
ConeDodger   I’ve run them on two separate engines. They are ...   Oct 9 2018, 07:37 PM
Bills914-4   The write up sounds awesome but so is the price. ...   Oct 10 2018, 07:53 AM
914werke   I revisited this thread & then looked up what ...   Feb 21 2026, 03:30 PM
mepstein   I revisited this thread & then looked up what...   Feb 21 2026, 03:56 PM
914werke   /6 vs /4 but yes 3K a chamber does sound expensive...   Feb 21 2026, 04:24 PM
mepstein   /6 vs /4 but yes 3K a chamber does sound expensiv...   Feb 21 2026, 05:12 PM
73-914   24V M64 Cylinder Head Kit Swindon Powertrain 42K ...   Feb 21 2026, 05:49 PM
mepstein   24V M64 Cylinder Head Kit Swindon Powertrain 42K ...   Feb 21 2026, 06:08 PM
7 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
2 Members: 73-914, T.Rick6
- Lo-Fi Version Time is now: 21st February 2026 - 08:10 PM
